AVS › AVS Forum › Home Entertainment & Theater Builder › Theater Room Items & Accessories › Any good and cheap 3 in 1 stands for a new 55" Samsung HDTV?
post #1 of 8
Hello.
Does anyone know of a good and cheap/low cost 3 in 1 stands for a new 55" Samsung HDTV (will add players and stuff later on)? They should be seen in person in local retail stores in Southern CA area (e.g., Los Angeles/L.A.) before buying. I saw a few in this week's Fry's Electronics and Best Buy so far, but they were a bit expensive and soso.
post #2 of 8
What in the world is a '3 in 1' stand?
post #3 of 8
http://media.tecca.com/2012/01/19/whalen-furniture-3-in-1-tv-stand-for-most-tvs-up-to-54-largefrontimage-320w.jpg as an example.
post #4 of 8
Define "bit expensive", for that kind of stand do you really want to go real cheap since part of it is going to holding your tv any ways? A site you should check out would be racksandstands to see what is out there, and give you a barometer of what to expect in terms of cost. For that kind of stand if you pay less than say $200 or so it's probably not only going to look "cheap" but also be suspect as well in terms of quality and durability as well. Usually when it comes to a/v furniture for the most part it seems you get what you pay for.
http://www.wayfair.com/TV-Stands-with-Flat-Panel-Mounts-C413915.html?keyword=&sortby=2&itemsperpage=40
post #5 of 8
Thanks. I assume it is racksandstands.com. Your URL shows cheaper prices.
post #6 of 8
Originally Posted by phildaant View Post
Hello.
Try Big Lots.
post #7 of 8
Apparently racksandstands is now part of wayfair, hopefully the service etc. will still be just as good.
post #8 of 8
