so i did the tvfool and antennaweb map lookups and unfortunately i cannot get up on my roof at this time (no ladder and my neighbor wouldnt let me borrow his....) but we have 5 antennas on the roof all pointing diffrent ways for the most part. It is a house with 4 apartments in it. as far as i can tell 3 wires or so go into the house in the two upstairs apartments, i seriously doubt if they use them becasue 2 of the wires come down into the basement under my apt and both are cut dead. So i got matching transformer hooked it up to one of the flat wires and a 50ft rg6 coax and had my tv scan for channels and this is what i got:
1 channel: 5.1
sig str: 0-30
phy ch: 90
freq: 621000 khz
mod: 8vsb
errors: 0-12713 dec
snr (db): 15.5 db
agc: 100%
this was unwatchable, signal lost every 3 seconds or so
then i switched the matching transformer to the other flat wire and got this
3 channels 2.1,2.2,2.3
sig str: 59
phy ch: 74
freq 525000 khz
mod: 8vsb
snr(db): 18.5 db
agc 100%
now as far as i can tell those 2 channels are in the same location/ close in the band with so idk why im not getting both of them on the same one, here are my tv fool results:
http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d990062c824eed8
basically i want as many channles as possible, right now im expecting to have to get up on the roof, move the antenna and install a powerful preamp/fm filter.
any help on what i should do? that tv fool result is like greek to me, but i will say that two of the antennas look like they are pointing north/north east towards the greenbay stations. ill try to get a pic of the roof for you guys with all the antennas if that will help, im thinking all the antennas up there is not helping signal either...thank you !
1 channel: 5.1
sig str: 0-30
phy ch: 90
freq: 621000 khz
mod: 8vsb
errors: 0-12713 dec
snr (db): 15.5 db
agc: 100%
sig str: 59
phy ch: 74
freq 525000 khz
mod: 8vsb
snr(db): 18.5 db
agc 100%
haha i was guessing before i got a good look, once i get up there do i use a matching transformer(thing with 2 prongs on one side and female coax on other) on the antenna itself then coax the whole way? or do i have to use 2 lead 300 ohm wire coming off the antenna for a foot or so then change it over? and how do i read the tv fool results and line the antenna using a compass? that is confusing to me, thank you so much guys
