AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › The best sub for ht/ tv for 2,000
post #1 of 10
For clean tight bass
post #2 of 10
Check this thread. I would spend a little more and get a submersives and then save up over time for a second one but that's me.
http://www.avsforum.com/t/1425179/the-subwoofer-recommendation-by-pricepoint-thread#post_22318553
post #3 of 10
I saw that but looking for other peoples opinions thanks.
post #4 of 10
Clean and tight I say go for sealed either dual (CHT18.1) or one big boy (18.2) if duals are not an option. Either of these will give you the best of both worlds, home theater and music.
post #5 of 10
My budget max would be 2,000 but if I can spend less that would be great I have no clue what a 18.2 is
post #6 of 10
Here you go https://www.chasehometheater.com/index.php?option=com_virtuemart&page=shop.browse&category_id=29&Itemid=53&TreeId=2&redirected=1&Itemid=103
And check out of "Sticky" Threads for the "Subwoofers, Bass, and Transducers" forum tons of info. you looking for.
post #7 of 10
Is a rythmic Fv15 hp a better sub than svs pb12 plus, pb13 ultra for the price
Edited by Sfniner - 8/18/12 at 8:48pm
post #8 of 10
Has anybody reviewed all three subs rythmic fv15hp, svs pb 12 plus and svs pb 13 ultra.
post #9 of 10
Yes, Audioholics.com has. Also the Data-Bass.com site has reviews for the PB13-Ultra and the FV15HP.
Edited by SaviorMachine - 8/19/12 at 11:49am
post #10 of 10
I should be getting my svs pb13 on Thursday thanks for everything. I might be upgrading my speakers next.
