Originally Posted by
DonH50
"Passive bi-amping does not utilize line-level crossovers; instead, two power amps are driven full-range into each speaker’s high and low terminals. The crossover (technically now split into a LPF and HPF) inside the speaker provides the filtering (“splitting”) of signals appropriate to each driver. The amps thus still provide a full-range signal, but the speaker’s crossover rejects the out-of-band signals to each driver.
A few key points:
Each amplifier requires the same voltage drive as a single amplifier since they each have the same signal. There is no voltage headroom benefit.
Because the load (speaker) is essentially an “open” in the unused frequency band, less current output is required from each amp. For example, the bass amp drives the woofer, but there is essentially no high-frequency current since the crossover “blocks” the HF energy. The opposite is true for the HF amp; the voltage swing is the same as a single amp, but there is almost no LF current so the net power per amp is less. Of course, this could potentially cause stability issues with the amp. Higher-order crossover networks may load the out-of-band frequencies to reduce their input into the drivers, increasing power dissipation the amps (which are driven full-range in a passive bi-amp system).
There is no net system power increase at the speakers assuming the amps have the same voltage rails (e.g. inside an AVR or multichannel amplifier with the same power voltage rails to all amps). If you had a 100 W amp before, passive bi-amping does not give you 200 W to the speaker. You have split the load into two frequency bands, but the net power is the same to the speaker. That is, 100 W to the lows and 100 W to the highs is the same as having a 100 W amp that covers the entire frequency range. It is not the same as driving the speaker with a 200 W amplifier; to increase the power, you need to increase the voltage rails.
In fact, there is more power lost, since the amps are not 100% efficient. That is, it actually takes more energy from the power supply to passively bi-amp than if you used a single amp. This is also true for active bi-amping, but in that case we can choose lower-power amps for the highs (which rarely need the same power as the lows) and realize net power savings. That does not happen with (typical) passive bi-amping.
There is no damping factor improvement over a single amp since the speaker crossovers are still in-circuit. One of the benefits of active bi-amping is direct connection from amp to driver, providing better driver control; this is not true in passive bi-amping. The lossy, passive high-power internal speaker crossovers must remain in place else out-of-band energy wil be applied to the drivers (causing at least distortion and quite likely destruction). This defeats one of the main reasons for bi-amping.
There is no longer electrical interaction among drivers with passive (or active) bi-amping. (There may still be mechanical coupling if the drivers are not isolated from each other.) That is, if the woofer starts to distort the input signal through electromechanical forces, it no longer modulates the HF amp’s output. One plus for bi-amping, active or passive.
If the amps share a power supply, as do most AVRs and many (most?) multichannel amps, then modulation between high and low amps can still occur through the power supply. This can also happen with active bi-amping, although separate amps are the norm in the pro world. At least when I have done it…
There may be some distortion reduction since power output is lessened in the amps. I suspect this is not significant, but it should happen due to the lower current draw. The catch is that the voltage swing of each amp is unchanged, so any distortion related to voltage swing is not changed. Only distortion components depending on output current may be reduced. That is
design-dependent, but since most amps are primarily voltage-mode amps, I suspect any distortion reduction is small.
You have two amps now so presumably noise is a little higher since you have two uncorrelated noise sources. At the speaker outputs I suspect it’s a wash since only a reduced frequency band gets through the drivers to hear.
Thermally it is a loss since no amp is 100% efficient. There is always a little “waste” power that gets turned into heat, both standing bias current (especially if not class D amps) and losses through the components in the amp. Thus passive bi-amping will cause your AVR/amp to run hotter than if using a single amp (assuming unused channels). It is worth noting that amplifiers are typically most efficient at maximum output; the HF amp is probably loafing most of the time and thus wasting power and generating heat.
So, there are some potential benefits, but I suspect they are inaudible (I have not tried passive bi-amping so cannot say). And a lot of drawbacks. The major benefit is mostly mental, IMO; users can now use their “extra” amp channels. Whether this benefits anyone other than the electric company I cannot say, but I strongly suspect not…
I did simulate a passively-bi-amped system just for grins. I used a simple first-order (single LC) crossover at 1 kHz and modeled the speakers with ideal 8-ohm resistors. I assumed 80 V rails (theoretical rails for a 100-W amplifier) and drove a relatively small signal into the speakers (1 Vpk at 100 Hz, 0.1 Vpk at 10 kHz). In the schematic below, the top is the single-amp system, and the bottom the passively bi-amped system. There is an input stage at left, combining the 100 Hzand 10 kHz signals to drive the amps, E1 – E3. (SPICE purists will note I did not need the dependent sources for this, but it makes the picture easier to follow.) I ran the simulation for 400 ms to allow the RMS power calculations to reach their final values.
The top plot shows the input signal; the “fuzz” is the 10 kHz signal riding on the 100 Hz tone. The second plot shows all the speaker voltages; note the woofer and tweeter signals are identical for the two systems as desired. Since I used only a first-order network, there is a little modulation of the tweeter by the low-frequency signal and vice-versa.
The third plot from the top shows the amplifiers’ RMS output powers. The single amp (P1) outputs 63.12 mW; the bi-amp system’s amps output 62.5 mW (P2, woofer) and 8.84 mW (P3, tweeter). Note that superposition does not apply with power, and P1 does not equal P2+P3. The extra power? Lost, wasted…
Looking at the power actually delivered to the drivers, the woofer (P1W, P2W) receives 61.89 mW and the tweeter (P1T, P2T) 1.239 mW for both systems (identical as expected). The power dissipation of the amplifiers, assuming 80 Vpp power rails, is 7.11 W for the single amp (Pd1), 7.04 W for the woofer amp (Pd2), and 1.00 W for the tweeter amp (Pd3). As expected, using two amplifiers costs a little power. This also highlights the inefficiency of amplifiers with relatively low output power. Unfortunately for our power-mad egos, average output is more often in the 100 mW to few Watt range than anything like 100 W.
