AVS › AVS Forum › Audio › Audio theory, Setup and Chat › Are audio companies all involved in a huge conspiracy?
Are audio companies all involved in a huge conspiracy? - Page 45
post #1321 of 3048
It would not be 200 wpc at any given time anyway but if the amp is 200wpc and he has 2 channels going to each speaker (1 to the woofer and 1 to the tweeter) then it may be true that 400 watts are available to each speaker at any given time. Does that mean that its going to be twice as loud? No. From what I understand bi amping is pretty much a waste of time when a crossover is involved. You may get a little bit cleaner sound if it is a high quality speaker.
Edited by Bond 007 - 2/7/13 at 2:43am
post #1322 of 3048
Originally Posted by Heinrich S View Post
His speakers are Polk Audio RTI-A9's.. so have a crossover.
So 200W won't fry his tweeters, because the crossover is "burning off" the low frequency energy that would otherwise destroy the tweeters. Of course, if you send an amount of energy the tweeter can't handle, it will go up in smoke anyway.
post #1323 of 3048
Had an argument with my friend over bi-amping and he tells me his 200 x5 Rotel, biamping his fronts sends 200 watts to his fronts for bass and 200 watts to the highs. I told him that 200 watts to his highs would fry the tweeter and tweeters can't handle that kind of power. I thought bi-amping would result in the same/similar power and not produce same to the highs and lows.
Bi amping does not double the power to the speaker? Is that what you mean?
Certainly, that is true.
The limit to the power delivered to most speakers is the voltage applied to them. Passive bi-amping does zero towards increasing the voltage available to the speakers.
IMO, passive biamping is an audio dealer scheme to sell more power amplifiers to people who don't need them and can't benefit from them once they buy them. It is a loss for the consumer. The only excuse is that most audio dealers are too technically unsophisticated to know what they are actually doing. You just don't find a lot of really good EEs in retailing or repping and most of the few of them that exist are too busy or scared to do right.
IMO, that otherwise sensible AVR manufacturers are indulging in this weirdness does not put them in a good light if technical integrity in the marketplace means anything.
If they wanted to extend the utility of their AVRs they would add amp bridging, which actually makes an audible difference and does not cost much more to implement.
Edited by arnyk - 2/7/13 at 3:36am
post #1324 of 3048
Precisely. And it is that crossover that would need to be bypassed if biamping were to actually make a difference.
post #1325 of 3048
Somehow I knew you would set the record straight arnyk. I wasn't real sure myself. Good info.
post #1326 of 3048
So the speaker does not "see" 200 watts for the lows and 200 watts to the highs because of the passive crossovers?
post #1327 of 3048
Heinrich S, I don't want to sound rude but you have to read up on the topic. There is only so much that can be explained in layman's terms. Maybe this helps a bit: http://science.howstuffworks.com/environmental/energy/question501.htm
post #1328 of 3048
With one power amp the speaker "sees" 200 watts for the lows and 200 watts to the highs because of the voltage limit of the power amp it sees.
With two power amps the speaker "sees" 200 watts for the lows and 200 watts to the highs because of the voltage limit of the power amps it sees.
There is no significant difference with passive biamping because the power amps amplify the same audio signal whether there is one power amp or two.
With active biamping, the power amps receive and amplify two vastly different signals. There is no crossover in series with the speaker drivers, which can waste power, big time.
Win/Win!
post #1329 of 3048
How is that? There is only 200 watts per channel. I would imagine only a fraction goes to the tweeter and the larger proportion goes to the woofer. You saying 400 watts? confused.gif Not sure.
Available doesn't mean used. In normal content, the power required for the frequencies the tweeter reproduces is about 25 percent of the power required for the rest of the audio band, so unless he plays white noise at very high levels, the tweeter will not receive high power. Ever. Because what you play doesn't have it.
I also suspect some misunderstanding that if I have a 200 watt power amp, I am feeding 200 watts to the speaker all the time. Not true. If we can agree that, all things being equal, a more powerful amp can make a speaker louder, we're halfway home. The speaker gets louder with higher voltage/more power input. That means it cannot always be receiving full power from the amp, because sometimes you turn down, and the speaker is quieter, and sometimes the content is not at full tilt, and the speaker is quieter. Actually most of the time. So when you''re listening mighty loud and the sound is 95 or 100 dB in room, you're likely using all of 5 watts or less, regardless of whether the attached amp has 10 total watts available or 1000.
And btw, as I understand it the high pass element connnected to the tweeter as part of the crossover does not burn off energy - - it'd likely need cooling fins if when biamping the tweeter element was getting 4 times the power it was actually using and converting the rest to heat. Instead the high pass presents such a high impedance to the amp below the crossover point that the amp does not make significant current (see Ohm's law) and the power delivered to the tweeter in the lower frequencies is inadequate to harm it.
Finally doubling power NEVER EVER doubles the perceived sound level. As long as the speaker stays linear (doesn't compress) doubling power adds 3 dB. That's going to sound "about one notch" louder, to most folks. Twice as loud is usually defined as 10 dB, and requires 10 times the power. Thus, for example if you're watching a movie with relatively loud dialog at 85 dB, that has explosions that use the max available headroom at 105 dB, the dialog is using 1/100 (that's right one percent) of the power that will be used for the explosions.
Edited by JHAz - 2/7/13 at 8:29am
post #1330 of 3048
Originally Posted by JHAz View Post
[quote na
Here is the schematic of a typical crossover:
Here is how the tweeter side of the crossover breaks down:
And here is what it looks like made out of real parts:
The two resistors that form the attenuator connected together in the upper left hand corner are indeed grey ceramic high-powered resistors that are designed to handle real amounts of power. However, as you say the high pass filter blocks most of the power so that the power resistors don't have to be the finned kind.
post #1331 of 3048
Originally Posted by arnyk View Post
Not a reply to Arny, he know this very well, but for those of you with close to no understanding of filters:
the capacitor does not like low frequencies as it will be charged up, but it has no problems changing/discharging fast.... so it will be working for letting high frequencies in towards the tweeter.
the coil is chaging it's magnetic field when a current is run though, so until done that will be blocking... low frequencies will keep going in the same direction and then it will be charged and work as a short circuit and not let low frequencies go through the tweeter....
So it's two components with opposite function, but they're also put in opposite ways.... capacitor in series with the tweeter, coil in parallel, so both with do the same.... getting rid of low frequencies.
(In the bass filter you change the order for the opposite effect. )
post #1332 of 3048
I thought the attenuator was to get the tweeter level correct when it is significantly more sensitive than the woofers (which must almost always be the case . . .) FWIW, for a while in my car the mid/highs were bypassed with just a cap to filter out lows . . .
post #1333 of 3048
Agreed. I hope I conveyed no other purpose for it.
That is pretty common in simpler and cheaper speakers. There are speakers with no visible crossovers. The inductance of the woofer voice coil cuts off the highs, and the tweeter is made in such a way that its natural frequency response is right for a tweeter with crossover.
post #1334 of 3048
Maybe y'all could answer a couple of basic questions while we're on this topic:
1. What is the shunt RC (22 ohms, 6.8 uF) doing across the woofer? Peaking the response a bit in the lows, natch, but why?
2. When simulating (SPICE), do you use a simple resistor to model the drivers, or are better (RLC) models available from the manufacturers? In the past I've just used a resistor, but now and then made more complex models to try to match measurements, but the latter can become a lot of work.
Curious, thanks - Don
post #1335 of 3048
That is a zobel which compensates for the impedance of the woofer rising with frequency, usually due to voice coil inductance.
http://en.wikipedia.org/wiki/Zobel_network
http://www.silcom.com/~aludwig/Sysdes/Thiel_small_analysis.htm
http://www.silcom.com/~aludwig/Sysdes/Thiele_equiv_circuit.gif
post #1336 of 3048
Drat, I know what a Zobel is, and have used similar circuits in the RF/mW/mmW world, should have caught that.
The driver circuit derivations and equivalents look the same as the ones in my grad acoustics text book. The one I never hoped to have to use again. smile.gif However, it seems like a lot of drivers provide T-S parameters these days so there is hope...
post #1337 of 3048
It's definitely marketing only, but it gives them an opportunity to suggest other uses for 11amps internally when a customer might only need 5. I've actually seen a shopper ask a sellrat just that question.
My (Onkyo) AVR digitises all signals after the input selector and does all processing in DSP, so it costs them a couple of lines of code to implement, and bridging would take no more effort and cost the same trivial amount (amortised across a squillion units). I'm sure many other units from many manufacturers are similar.
post #1338 of 3048
It's definitely marketing only, but it gives them an opportunity to suggest other uses for 11 amps internally when a customer might only need 5. I've actually seen a shopper ask a sellrat just that question.
Exactly. The hardware is there, so why not use it, well that's the logic. It is arguable whether passive biamping actually constitutes a worthwhile use. Technically, it is not.
All AVRs that I've seen the service manuals for have a similar architecture. FWIW the DSP is preceeded by a massive source selector that includes an ADC for analog inputs. The DSP is followed by an analog volume control chip which is what drives the power amplifiers. The analog volume control chip seems superfluious, but it is there in every case I've investigated so far. It doesn't hurt the SQ because its performance is very good.
post #1339 of 3048
Here's a good general reference:
http://users.ece.gatech.edu/mleach/lowtim/output.html
All of the lower half transistors are a mixture of PNP and NPN transistors tricked up so that they work in a way that is similar to Figure 1. This method was used because in the early days of SS, PNP output transistors were like hen's teeth. The asymmetries lead to somewhat poorer measured performance, but the circuit could be perfected well enough that they sounded the same, anyway.
Yes. All of the transistors have become far less costly for a given power level. I can remember when fairly crappy fragile output transistors cost over $30 each. In similar quanties a far better part may be now less than a dollar. The SS devices have also become faster, better able to withstand heat, have more gain and are better able to handle reactive loads and shorts. The actual circuitry has not changed all that much. In some low end AVRs the output stages are implemented as single chip or as a hybrid integrated circuit, but the performance can still be more than good enough.
You mentioned two dates, 1975 and 1985, and I suspect your $30 number is referenced to the dollars of that day. If so, FWIW, indexed to today's $, that would be in the range of $70.
post #1340 of 3048
Mine is done in the digital domain with the only "processing" post DAC a 20dB gain opamp in the LFE.
post #1341 of 3048
Don't remind me! At one time I was quite the experimenter with fairly large SS power amps. One little mistake and 8 output transistors are toast!
Just for reference I was looking at the specs for some modern output transistors. They were about $5 each in small quantities. 50 MHz instead of the 3 MHz parts I used back in the day. They had 4-8 times the reactive load handling ability. Where I used to use 4-8 devices costing $50-70 each in today's dollars, today I would only need to use 1 each $5 part that mainstream manufacturers are probably paying $1 or $2 each for in production quantities. And people wonder why AVRs line up 5-11 power amp boards like cord wood and sell them for a few $100.
post #1342 of 3048
Where are all the DBT's of DAC comparisons? I see there are a few CDP comparisons, but nothing much on external DACs. Anyone have a link to a DBT or a few credible sources on DACs that are independently verified?
post #1343 of 3048
Did you try Google?
http://www.matrixhifi.com/molingordo5_pc_dac1_beh.htm
http://www.matrixhifi.com/contenedor_conver1.htm
http://www.matrixhifi.com/contenedor_dac1.htm
post #1344 of 3048
post #1345 of 3048
Originally Posted by RUR View Post
IMO Matrixhifi is suspect and I wouldn't rely upon their testing. http://www.avsforum.com/t/1336902/how-do-i-verify-or-debunk-the-claims-of-the-upgrade-company/1560#post_21959400
YMMV
You mean this one?: http://www.avsforum.com/t/1290427/berkeley-audio-alpha-dac/120#post_19727968 Looks like he fizzled out when questions got more specific. frown.gif
post #1346 of 3048
This is the problem. It's often hard to decipher what is relevant and reliable from the irrelevant - what DBT/ABX tests are reliable accounts and can be trusted? Because it really gives the anti-science camp even more leverage than they probably deserve.
post #1347 of 3048
He's a professional NVH engineer whose baseline test conditions report, requested by his (former) Matrix fellows, makes for interesting reading. He also answered questions via PM and on another forum.
post #1348 of 3048
In other words, if there are no published reliable accounts of DAC DBT testing then one cannot dismiss their claims out of hand. They could just turn the tables on you and you would be defenseless. biggrin.gif
post #1349 of 3048
Not all DAC DBTs are published online. If you are that skeptical of the results published by others, there's only one option left for you, it's time to DIY.
post #1350 of 3048
But shouldn't we all be skeptical unless the results were independently verified? Or should we accept the results by default? If the DBT's aren't published online then that's great. So no one will know ... except for the relevant parties involved in the testing. It doesn't sound like a particularly credible stance to hold, although I do believe that DACs largely sound the same under controlled testing. It's just difficult to prove or at least show evidence of such a thing.
The anti-science brigade will demand evidence of DBT testing results of which none can be found and round and round we go .. biggrin.gif So although their position may be weak the alternative doesn't strike a whole lot of confidence either.
