Originally Posted by
goneten
In other words, if there are no published reliable accounts of DAC DBT testing then one cannot dismiss their claims out of hand. They could just turn the tables on you and you would be defenseless.
What makes you say so?
Any controlled subjective listening test of digital audio kit must by definition have a DAC in the signal chain, right? Therefore, with the exceptions of tests about different transports (disk spinners or computers) feeding into a common DAC, every test involving digital audio kit is also a test of different DACs.
kiwi2
It's the absurdity of someone saying... "science has proven all DACs sound the same" (which it hasn't)...
When you can show a seriously-conducted (level matched, blind) listening test of DACs that shows a sonic difference in the absence of phenomena well known to allow differentiation (FR errors, audible hiss/buzz/hum, etc.) then...you should publish it. But until then, let's just agree that for all relevant and material purposes the matter is entirely settled.
kiwi2
Another hobby of mine was photography. In photography forums you would quite often get the "science" type that would have all the measurements and resolution charts and test shots of brick walls with all of his lenses as if somehow that would make better photographs. What those type of people usually overlooked is that photography is partly science and partly an art form. Subsequently these people usually also had the most boring unimaginative and poorly executed photography work in their photo albums to show for it For me music is also partly science and partly an art form. *** .
No.
Production of art is an entirely separate discipline from
reproduction of art. Often the problem in these discussions come when people come in with a confused and insufficiently rigorous thought process, such as the one described in words above, and therefore fail to understand the fundamental distinction between production and reproduction. And, of course, audio parts makers/marketers love it when that distinction is blurred, because it raises their collective status while allowing higher markups.
But the bottom line is that audio is to photography as a photo-copier is to a symphony.
kiwi2
*** Reproducing music in my listening room is also partly an art form.
It shouldn't be, if you want it actually done right. Alas, just as getting reproduction of a 2D visual piece of art (such as a photograph) right one probably does require to looking at boring and tedious things such as prints of pictures of brick walls, getting reproduction of a 3D audio piece of art (a song, a symphony, spoken word, ambient noise, whatever.) right in a room requires looking at boring and tedious things such as steady-state frequency response in the modal region, direct-field response of the loudspeakers, polar maps of the loudspeakers, etc.
