Originally Posted by KidHorn
Could be. I don't really care why it sounds better.
Ignorance is bliss. ; )
) I think the reason people like myself get involved and bring up these caveats is because we want to help. I don't care how much money someone spends on their system but if they ask how much they should spend and why, well, I'll offer up my opinion.
. Was picking as an example of a common product where the question here can be directed. Do we have a belief that they are transparent to each the source?
. The problem becomes non-linear distortion. Take 128 Kbps AAC compressed audio. That encoding can have ruler flat frequency response and near zero distortion. Yet it can have a non-linear, data-dependent distortion on transients called pre-echo that can be audible. The system has no distortion in one instance, and large amounts of it just a few milliseconds later. For this reason we never evaluate compressed audio using audio measurement tools. We only use listening tests as the measurements simply do not detect the distortions that are clearly audible. Computer modelling exists for those artifacts but is insufficient (or else we would dispense with listening tests).
. To that end, I have a set of criteria that I use to establish transparency. But try as I have, I can't convince many of the vocal members here of them. They like far lower thresholds. Take CD audio at 16 bits. I say we should have a system that actually resolves 16 bits of dynamic range. They say no, that should not be the goal. They say that we don't need that because X, Y or Z reason. That's where they lose me because it is not expensive at all to achieve such comfortable targets. I don't get why I should settle for 13 bits of resolution where I can mathematically demonstrate it to exceed threshold of audibility. And again, can achieve that with very low cost. Why advocate how bad can we make the system before someone complains?
