May I ask where you got this "factual" information from?Originally Posted by kodi41
I think what is happening here is not science, but rather, opinion. We simply can not prove what sounds better.
As I previously stated, and I stand by this, take for example an AB International 900A, 370 at 8ohms, 2 channels driven from 20 to 20k. Now compare that same amplifier to say a Cinenova Grand used in 2 channel mode (365x5 @ 8ohms 20-20k). IS there a difference in sound when using these amplfiers on the exact same pre-amp, disc player, speaker and cabling ect. I will say yes there is- but not a huge difference, and for several reasons. Which if you read from the previous link I provided for you, it will help explain why this is. This link is from QSC, a premire profesional amplifier designer.
As well, let's lower the bar here using the same senario from above, and use say an Audio Source amp 200 (100 wpc 20-20k) and compare this amp to say a Krell KSA-100A, also 100 wpc, however, this amplifier is pure class A. I promise you, unless you are deaf, you WILL hear the difference, and it will be HUGE.
So please, let's compare apples to apples - there are very large differences in percived sound quality when build quaility and amplifier type are considered. No sane person plops down 20k for an amplifier that sounds lesser then the previous amp they had. After all, If there were no differneces in sound quality then one design would bear this out and it would be the prefered amplifier of choice. There-fore, it becomes a thing not of just preference but of "how much would you like to spend".
Stating that 100wpc from amp A sounds the same as amp B is akin to saying a Kraco system sounds as good as a Parasound system of equal power rating- not a chance. Even at 1 watt- the Parasound will blow the Kraco out of the water. This is known as build quailty fellas, and it makes for big differences. We could go further and state that all elecronics be it audio or video perform the same, they in fact do not.
However, and I strees this point, at a certain price point and build quality it becomes a mute point, rather, it then becomes a thing of personal preference.
