Originally Posted by Nightlord
That kind of test has no relevance for real life. If you are limiting the test to what's possible to compare in that way, you ignore how things are in real life. And then you end up with a statement that "all amps sound the same" which only is correct within that small subset. While the truth is that almost every amplifier made can be detected when compared to the signal it was told to amplify and it's quite hard to make different designs color exactly the same.
A lot of people seem to think that these tests are for consumers. In some sense they are, but I think they're best for designers, who can use them as input data on what sorts of changes customers can actually hear. Design updates can be expensive and it's best to concentrate on those that will actually be perceived.
