I'm planning to purhase a 100" Enlightor 4K AT screen and place it in a dedicated theater room. I don't plan on cutting into the drywall because it's up against an ICF concrete/foam wall with sound clips and furring channel... leaving only an an inch or so behind the drywall. I was thinking of using a black ATS acoustic panel 4" thick and cutting holes for some Paradigm in wall speakers (with their backbox) and then placing the AT screen 1" inch in front of the speakers. This would leave 5" between the drywall and the false wall on which the AT screen would be placed. I would place all 3 LCR speakers behind the screen starting at about 30" from the floor (the screen will be 24" above the floor). Each speaker is 36.5"H and 9" wide. The edge of the the L and R would be placed about 1' from the edge of each side of the screen. Does anyone have any better suggestions on how to do this? Any help would be appreciated!
Here's the link to the acoustic panel from ATS... http://www.atsacoustics.com/item--ATS-Acoustic-Panel-Custom-Size--1012.html
I'm redesigning my room to add better symmetry to my planned room per Big's advice. I thought about making the screen larger to accommodate all three speakers behind. Do you iknow what size of screen would be required/recommeded to do this. I'm just trying to noodle this out a bit more... and gain knowledge in the process. Thanks!
