Hello,
I need help changing code for an Axcent3 control system installed in 2005. The unit is controled via wireless touch screen and run through an autopatch to accommodate two Mitsubishi projectors. The axcent3 sends commands via rs-232 to the projectors. They use vga as well as composite to for the dvd player and doc cam. The projectors have both gone bad and have been replaced with new Mitsubishi projectors. I tired my best to match them up as much as possible but all of the newer projectors only have s-video on video1 so im stuck using a converter which now has horrible picture quality. The Mitsubishi has a video2 that is composite that I have tested and it looks perfect! I just need to know where I need to start and a bit of help changing the code if possible it seems like a simple code fix to me. Please someone help me out with this
