AVS › AVS Forum › Audio › Speakers › On-wall speaker suggestions
post #1 of 7
Hey Guys,
Looking for some on-wall speaker suggestions. Some bookshelves with wall mount options are also good. These go next to my 60inch Samsung flat panel.
Budget for Left, Right, Center = ~$1200ish
I currently have Energy takes which are great and surprisingly somewhat fill the living room (1000 odd sq feet). As you can tell, I am not a critical listener
I am planning to use this set-up for 60% HT and 40% streamed music. This along with some Sonos or Audioengine speakers should help with my Sonos set-up as well.
I may end-up with Sonos speakers for kitchen etc as I'd have to run wires for Audioengine. Anyways, that's altogether a different headache.
Options I am considering:
[1] B&W 685s for L,CR,R - Requesting wall mount options
[2] Kef Q300 + Kef Q600 - Requesting wall mount options
[3] Definitive XTRs - Haven't heard them, but read good reviews
[4] Totem Tribes - Haven't heard them, but read good reviews
I am guessing any of these would be better than in-walls?
Appreciate your inputs!
post #2 of 7
Originally Posted by iAusio80 View Post
Hey Guys,
bump ;-
post #3 of 7
If you like the sound of the Take speakers, I would think any of the above would sound good. That said why do you have to wall mount bookshelf speakers? Do you not have the option of using stands? Otherwise I tend to like the on-wall options if you have to go on-wall. The Deftech and Totem speakers look interesting. With any of these choices you will want a dedicated subwoofer, have you budgeted for one?
post #4 of 7
Thx!
I'd prefer wall mount to keep a clean look and also avoid them being knocked over by dog or get pounded by the robotic vacuum cleaner.
I really did start with floorstanders in mind, but have kind of moved away assuming bookshelves wouldn't be a bad sacrifice.
I've heard the 685s and like them, but the Kefs seem to have good reviews and are slightly cheaper as well. I could get a pair @ reduced price from A4less.
I haven't heard the Deftechs or Totems. I do have a PA subwoofer. Not earthshaking, but kind of does the job. Could always get an SVS or Rhythmik in the future ;-
What I was looking for is to itemize the top (within the budget) bookshelves or on-wall speakers and then narrow down per reviews and auditioning.
post #5 of 7
fwiw, pair of nht classic3's and classic3 center.these are acoustic suspension designed (no ports) so they can be mounted to walls if you don't mind buying used there are pair of classic3's and center on audiogon for $700 obo
post #6 of 7
Two good options from Focal
The 705V can be wall-mounted - with the good price, buy 2 pair and use one as a center channel.
The regular center channel is more expensive. Special price here.
http://dedicatedaudio.com/inc/sdetail/34397
The Focal Sib XL is another option
http://www.musicdirect.com/p-4906-focal-sib-xl-speaker-ea.aspx
post #7 of 7
Great!. Need to find a place to audition.
List in no specific order:
[5] Focal 705V
  Back to Forum: Speakers
