AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Can attaching this to your TV cause a plasma panel to go bad?
post #1 of 7
Might be a dumb question but can attaching these led lights to the back of a plasma TV cause the panel to go bad?
http://www.cyron.com/p-109-media-highlighter-pro-system-htp904e-enhanced-4x9.aspx
post #2 of 7
No.
post #3 of 7
Another dumb question. Why would you want to attach lights that change colors behind your tv? Bias lighting is supposed to be as close to 6500k as possible on a neutral wall.
post #4 of 7
Why not one of these thats the right kelvin. http://www.cinemaquestinc.com/ideal_lumesb.htm
post #5 of 7
You can leave them on a single color. The white looks pretty subtle. Changing colors are nice when playing music.
post #6 of 7
True. But if you want a bias light (single color) the LEDs aren't going to produce anywhere the proper temperature and not even close to a CFI of 90 or greater.
post #7 of 7
I'm sure you are right. I was not looking for bias lighting when I bought that. Just some accent lighting/color for the media area. Mostly for music when the TV is off or when I have ambient programming on while listening to music.
People seem to like it and it does not distract from the TV when in use IMO.
