AVS › AVS Forum › A/V Control & Automation › Remote Control Area › Can see and add devices but can't control them.
post #1 of 5
Hello,
I have an Direct TV HR22 hooked up via cat 6, a Pioneer VSX-45 hooked up via serial. I have added the devices. I have added what i feel like is correct functions but I can't seem to get any response from any device. I have reset modem-router, switch, dvr, etc. Still no luck. Gotta be something simple. Also does anyone know which one to pick from Pioneer for the 45vsx as it's an older unit? Thanks in advance.
post #2 of 5
It would be helpful if you mentioned exactly what it is that you're trying to program.
post #3 of 5
Trying to turn any of the units on, or do anything. Can't get any response from either unit. Tried changing delay and also sending info twice to the units.
post #4 of 5
We really need to know what hardware/software/device you are using to send the commands. Then, you need to tackle one device at a time. Have you used RS232 before, are you certain the wiring and port speeds are correct? We really need a lot more detail.
post #5 of 5
Sorry i posted this in remote control area instead of in roomie remote thread. Will move it. Was wondering why i was getting questions like this.
  Back to Forum: Remote Control Area
