AVS › AVS Forum › Video Components › Home Theater Computers › Would a core 2 e5200 cut the mustard 3d playback
post #1 of 25
Hi all going through my cupboard today I came across a core 2 e5200 with 4 gig of ram now if I was to buy say a nvidia 430 graphics card. would that cut the mustard with 3d play back on power DVD 12 . As I am sick of having to unplug my monitor from my pc with a duel screen setup to watch 3d
post #2 of 25
A core2 should be able to play back video fine with an appropriate video card.
post #3 of 25
Thanks fella. So you reckon with a nvidia 430 it should all be fine then
post #4 of 25
Cut the muster..
post #5 of 25
I don't see why not. A core2 is not modern but it is not horrible. With a video card it should handle playback fine.
post #6 of 25
I use a Intel Core 2 Quad Q6600 and an nVidia GTX 460 for my 3d playback. It works very well. I upgraded the processor from a dual core and it struggled on 1080p 3D playback.
post #7 of 25
Well I was just about to order the graphics card then I read that last post. Guko what duel core chip did you have trouble playing 3d content with mate
post #8 of 25
I have the same cpu, and in the past, I've had trouble playing high bit rate videos (like blu-rays) on the CPU alone, although it was borderline so YMMV. With a discrete GPU with hardware acceleration on you will be perfectly fine.
post #9 of 25
Thanks lockdown that's just what I wanted to hear. I'll order my bits now
Ideal fella
post #10 of 25
Why do you have to unplug the other monitor? Does it make the video stutter or does it just not play 3D that way? Just wondering if it's an HDMI issue or just the hardware. In a lot of cases if a HDMI chain has a non 3D monitor in the chain, it won't do 3D on any of the monitors.
post #11 of 25
You hit the nail on the head wyen there is a non hdmi monitor in the chain
post #12 of 25
You sure the gt430 is still the card to buy?
post #13 of 25
Jeffkro give me your thoughts mate as I was running it with a 6850 but need that for my main pc
post #14 of 25
I'm running an e5200 with a gt430, no issues with 3d play back using total media theatre 5.3 I believe is the latest version.
but I believe the gt 6xx is the latest rev of the fermi
Edited by dbailey75 - 8/20/12 at 5:04pm
post #15 of 25
Yeah you could be right if you are looking to keep price down for an older system. The lower end version of the 28nm graphics chips aren't out yet, you could also look at the HD6450, but if I remember right you need the 64bit ram version
post #16 of 25
Originally Posted by Sammy2 View Post
Cut the muster..
http://en.wiktionary.org/wiki/cut_the_mustard
http://www.phrases.org.uk/meanings/cut-the-mustard.html
"cut the mustard" would appear to be correct
post #17 of 25
lol
post #18 of 25
http://checkgrammar.blogspot.com/2006/11/check-grammar-cut-muster-or-mustard.html
Originally Posted by Check Grammar
Cut the Muster or Mustard?
The saying (idiom) goes like this: Cut the Muster, not Cut the Mustard. The modern sense of the idiom is to succeed; to have the ability to do something; to come up to expectations.
This etymology seems plausible at first. Its proponents often trace it to the American Civil War. We do have the analogous expression “to pass muster,” which probably first suggested this alternative; but although the origins of “cut the mustard” are somewhat obscure, the latter is definitely the form used in all sorts of writing throughout the twentieth century. Common sense would suggest that a person cutting a muster is not someone being selected as fit, but someone eliminating the unfit.
Sorry but muster means to pass inspection whereas mustard is a plant. If you are inspecting parts for a computer build it is "cut or pass muster". If you ar making a sandwich it is "pass the mustard".
post #19 of 25
Is that yellow, spicy brown, or dijon? Personally, I like
post #20 of 25
LOL..
post #21 of 25
post #22 of 25
post #23 of 25
That's not Frenches.
http://www.youtube.com/watch?v=FU08UYGSNKU
post #24 of 25
It is the best.. No vinegar. Just mustard and water with a few other minor spices.
post #25 of 25
Thanks for all your help fellas. Slapped it all together yesterday and chucked a SSD in there to and it cuts the mustard a treat biggrin.gif ideal
