I am a tinkerer by nature. I generally don’t have a need for most of the things I buy but I do any way.
I bought my first pair of LG HW300T’s on 23 May 2012. I was so impressed that I purchased a second pair a week later even though I knew of the upcoming improved models.
So what do I think after reading the impressions of the new models and my purchase? I made good buys.
That is, I would still buy at least two because they are THAT impressive. The jury is still out on whether the output levels in the economy (max power saving) mode of the newer LG projectors is much better than the HW300T. My impression is that the new units are quieter but without more environment info I cannot evaluate if that would be true for me.
I have two units (D and C) connected to a 4x4 HDMI Switcher. I feed a 4x2 switcher into the 4x4. I have 4 computers connected to the 4x2. The 4x2 also has a coaxial optical output. On average, I use my Dell 530 Inspiron (Q6600, AMD 5450 vid card, winXP) during a 24 hour period from 0600 to 0100. That is 7 days a week with a typical day well over 12 hours.
I live in a suburb of Phoenix. In case you don’t know it I live in the desert. We just had the hottest first two weeks of August with six days of record highs. During the day, I keep my work space between 88 – 92 degrees Fahrenheit-barely at the limits of comfort. The hotter the day the warmer the room and the more the fan noise from my 300Ts (in economy mode) but they NEVER got hot to the touch. On cooler (yeah right) mornings I could use the “normal” power mode for the same noise as economy mode until the afternoon.
I mainly surf the web, write, and watch TV and movies during the day. I use the “D” unit as my primary unit. My bedroom is 28x20x10. I project an image 80 inches wide from 9’3” away and 19 inches off the floor. My walls are off-white (Coffee is the color. It appears to be warmer (red) in balance.). Three of my projectors: A, C, and D have a green tint when I select the medium color that requires the expert picture modes to adjust. Even then there is still a green but less objectionable tint. The B unit has a blue tint that is less objectionable because it is projected on a warm tinted wall. My projection wall has a door on the left and a hall on the right that permits a lot of desert sun to enter during the afternoon.
I use the AVS709 disk that someone created on this forum to quick calibrate my projector several times during the day. The five common files I use are: 1-Black Clipping, 2-APL Clipping, 3-White Clipping, 4-Flashing Color Bars, and 5-Sharpness & Overscan.
For a quick calibration I do the following in the expert mode
1. set the black level to HIGH
2. set the brightness (1-Black Clipping),
3. set the contrast (3-White Clipping),
4. check the 2-APL Clipping,
5. set color and levels using 4-Flashing Color Bars and the blue color filter
6. check my focus with 5-Sharpness & Overscan
To maximize my light output and picture I set my equipment as follows:
I. AMD 5450 (HDMI) DEFAULT: 1680 X 1050
II. LG HW300T:
1. LED Mode: Economy mode
2. Aspect Ratio: FULL
3. Picture Mode: Expert1 (RESET first)
Then
1. Contrast: 86
2. Brightness: 67
3. H Sharpness: 59
4. V Sharpness: 81
5. Color: 55
6. Tint: 0
Expert Control:
Black Level: HIGH
Color Temperature: MEDIUM
Gamma: 2.2
Red Contrast: 5
Green Contrast: -23
Blue Contrast: 11
III. Zoom & ffdshow ... (Combined-Community-Codec-Pack-2011-06-26 & zoom 451)
Picture properties: contrast: 141 brightness -2 gamma: 0.79 saturation: 70
Levels: original modify only luminance: X full range: x
Input: 3 ~ 230 output: 0 ~ 244
IV. Daum PotPlayer 1.5.29162
Lower left corner: INITIALIZE the Program
1. Video Setup
Video
Video Renderer: EVA (VISTA /.NET3)
Colorspaces
Brightness: 8
Contrast: 117
Saturation: 72
Color: 0
Levels/Offset
Level Control: x INPUT 16 ~ 235 OUTPUT 3 ~ 255
Gamma Correction: 114
Video Processing:
Sharpen: LUMA 250 ... CHROMA 200
Motion Blur: X (creates intermediate frames)
The reason I specified my playback software is that it is essential to get the most out of my HW300Ts. External (software) level, gamma, and contrast control is crucial to improving black level and contrast ratios. I particularly like the Daum Potplayer because it allows me to play 1080 video on my AMD C-60 but there are limits on the amount of optimization you can do because of the processor speed.
When my “D” unit is turned on it is blurry (well what did you expect at 1000 hours). I just wait a few minutes and it is in focus as best as can be expected at 1680x1050. I chose that resolution to be able to improve the quality of text at larger font sizes. The scaling process is more forgiving. I use Opera as my primary browser because it allowed easy zooming for years. Zooming text is a critical factor for day long web research to prevent extreme eye fatigue. I use Power Desk as my file explorer because it allows custom size fonts. So although the diagonal pixels are a concern they have not stopped me from using the projectors as a second monitor. I still prefer a standard monitor as my primary but I always have the other active for a dual display use (like Google Earth).
I use the 5-Sharpness & Overscan calibration file to adjust the sharpness of my HW300T. The more rectangular the projected display the more even the focus. I try to avoid keystone correction.
My tinkering projects: 3D and Home Theater.
First, let me discuss 3D.
I needed two projectors to use in a dual projector set up for 3D. I am still waiting to create a larger screen (I have the items assembled). The dual projector 3D process was simple: 2 HW300Ts, 2 pair of movie 3D polarized glasses (1 cut a lens placed over each projector), a silver screen, AMD 4000 GPU and up, WinXP and SBS 3D material. I used the horizontal stretch feature via the AMD Control Center that doubled the output display horizontally and simply played the SBS 3D file in a compatible player with the aspect ratio set as free). The players were stacked using letter trays and index cards to align the images. The smaller silver screen did not do 3D justice but the 3D effect was there.
(Note: The high gain of the screen caused me to see a lot of rainbows. I am extremely RBE (RainBow Effect) sensitive and took a chance on the LED DLP technology. The only consistent circumstance for me seeing the annoying RBE is during high contrast and warm (color temperature) balanced scenes. Fortunately, for me I prefer cooler (bluer) balanced pictures. But until I deploy my larger high gain screens I can’t know whether or not I will still have a problem with RBE.)
The greatest annoyance with 3D for me is the lack of support for dual projector systems. There seems to be a concerted effort to push the 3D electronic shutter systems and AVOID dual projector 3D systems. I have little interest in expensive glasses. I do tend to drop things.
Now, let me discuss my Home Theater experiments.
1. The HW300T plays video files quite well. One member reported that it does not play DTS files and I had that experience too. For a simple home theater, one need only connect a USB device (like my 2GB HDD or Thumb) with movies and play them. The unit outputs audio through a mini headphone jack. I want to find a wireless FM transmitter to use (I found one that uses USB. Unfortunately, the HW300T does not support USB hubs so only one device can be connected at a time.)
2. The second way to easily create a home theater experience is using the WiFi dongle to connect to your personal network. That too worked well. But again there seems to always be a price. Security! I could not disable my internet connection and use the access to my network to play movies. That meant that I had to trust LG to keep my net safe because internet access had to be active to play movies. I don’t trust so easily so I don’t use the network function.
3. The third way to watch movies with the 300T is over the air. I have my units connected to Cox Cable. The images are quite impressive using the “Vivid” Picture Mode. They are oversaturated but very impressive. The 300T allows me to change the settings and they are automatically saved for each of the picture mode (one each for DTV and analog cable). I am pretty sure it is based on the resolution differences-hidef resolutions have one set and lower def analog have another set.
4. The fourth and most common means was using the inputs: HDMI, Composite, RGB-PC (VGA), and Component and supplying source material. I used the HDMI and VGA inputs.
More Notes:
1. My preferred aspect ratio is 16:10, the projectors default ratio and my preferred resolution is 1650x1080 whereas the projector is 1280x800. However, if I use the 16:9 setting more options are available on both my video card AMD 5450 (using the video option) and the picture mode: Expert1/2. That is both 1080p and 720p give you the extra options.
2. Setting the “Aspect Ratio Mode: Just Scan” and using the “5-Sharpness & Overscan calibration” file you get an Overscan of 0% and a 16:9 picture.
3. I doubled the light output from my HW300T by stacking two units and using index cards to align the two units. Over 70 percent of the screen was aligned and the results were stunning. Brightness does make a huge difference. But note that I can approximate a doubling of brightness by moving my projector 30 percent closer or using a 2x gain screen. My screen for 3D will be a high gain screen. But I don’t know what the final gain will be. The dual projector with stacked double output (and control settings) offered much greater flexibility in controlling the picture.
4. One more tool I used in my home theater experiments was a simple fixed iris to increase the contrast on the 16:9 output area of the 16:10 chip. It was a simple but limited (for now fix).
5. My final home theater experiment was a dual side by side experiment. I used two projectors much closer to the screen (wall). The result was a substantial increase in brightness. I set the projectors in 1280x1024 and used the AMD Control Center to create a 2560x1024 display for use with 2.35:1 material. I played several video files and I was very impressed. But like all tinkering there were problems. The first was that I had to place the projectors about four feet a part (not pretty). The second was I had to align the image to the pixel (I looked into buying an AMD Firepro card with its edge blending software but that seemed to be too expensive of a solution). I got the alignment close enough to enjoy the image. The last problem was matching the displays. Under no circumstance could I get the colors of two (of my four) units to match. If I had proper equipment to calibrate the displays then maybe I could have done it but once again the solution was not reasonable.
I didn’t include any home theater settings because I prefer to use the panel in the 16:10 mode. When I finally figure out the decorating scheme that allows me to install my huge projector screens then I will concentrate on refining my settings for home theater.
BTW, my jaw dropped because it felt like I was looking into the wall with the double stacked projectors experiments. So my current delay is to decide whether or not it is worth it to buy two of the newer projectors because they have the controls on the side and back. But I read about a WIDI version and I think I’ll hold off for that.
As I finished writing this, I should note that was another problem that bothered me: there were times when the projected images were simply dull or flat. It seemed like the black levels and contrast had dropped off a cliff. There was a muddy picture. This also happened on broadcast TV. I would reset the display to the default Picture Mode: “Vivid” and I would still have a dull flat picture.
With the TV I would switch the Picture Mode or to a different channel and that seemed to solve the problem (This is on a unit with much less time but in a warmer part of my house.).
When it happened on video that I knew should look better I immediately started adjusting the levels and the picture transformed.
Okay, one more thing: everybody expects LED to be long lasting and I hope that it is but I bought a half dozen LED USB lamps last year (two different orders) and they all had unusable outputs within a couple weeks. I also have had LED night lights (that I use as mood lights) through out my house for over six years and several have lost quite a bit of output.
II. LG HW300T:
Then
1. Contrast: 86
2. Brightness: 67
3. H Sharpness: 59
4. V Sharpness: 81
5. Color: 55
6. Tint: 0
Expert Control:
Black Level: HIGH
Gamma: 2.2
Red Contrast: 5
Green Contrast: -23
Blue Contrast: 11
1. Video Setup
Video
Colorspaces
Brightness: 8
Contrast: 117
Saturation: 72
Color: 0
Levels/Offset
Video Processing:
More Notes:
