AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Antehm MRX 500 + 2 subs
post #1 of 3
I am based in the UK and I am looking at purchasing the MRX 500 it will only be used for movies nothing else and wanted to know if I would be able to run 2 Velodyne SPL 800 Ultra's ?
I have heard positive things about Anthem amplifiers, as I have spent a small fortune on getting a dedicated room built for movies and nothing else with Monitor audio in wall speakers 7.1 and 2.40 acoustically transparent screen projetcor and anamorphic lens.
I currently have an Denon 2808 and 1 Velodyne SPL 800 Ultra and wanted to upgrade as I have had my current amp for some years...
I was also considering the Denon 3313 and is a dedicated 7.2 amp which is considerably cheaper any advice would be appreciated.
post #2 of 3
http://www.avsforum.com/t/1425218/anthem-mrx-500-2-subs
I already answered your previous almost identical thread. You ignored it and now start another thread, that's a funny way to show 'any advice would be appreciated' and not polite forum etiquette is it?
post #3 of 3
....excuse me....I didn't mean to cause any offence, i'm quite new to having a decent Home Theater set up after years of wanting it and am genuinely appreciative of any advice....
