AVS › AVS Forum › Audio › Speakers › Need replacement 8" woofer for Snell Type E
post #1 of 5
These are my dad's speakers and he is looking to replace the woofers. Not sure what generation type E's he has but from the Snellacoustics.com site, all generations of type E use the same woofers.
Anyone out there know of a compatable and comparable driver to use as a replacement. He doesn't want to spend the $176/driver from Snell.
post #2 of 5
Are the foam surrounds dry rotted?
Contact Simply Speakers, and communicate with them.
http://www.simplyspeakers.com/snell-speaker-foam-edge-repair-kit-fsk-8.html
post #3 of 5
Not sure if they are rotted. If so, is the foam edge a difficult thing to install?
I guess we could try this option and see if it fixes the sound problem he is having.
post #4 of 5
If the woofers have holes in the surrounds - then they need to be refoamed.
A lot of people buy the kit - and do it themselves.
post #5 of 5
How would I know if the woofers actually need to be replaced?
  Back to Forum: Speakers
