AVS › AVS Forum › Audio › Audio theory, Setup and Chat › Mixing HDMI and Analog to SPDIF
post #1 of 3
Hi All
We have a configuration at work where we use a laptop connected to a TV via HDMI, which is then connected to a soundbar via SPDIF.
We have some con calls where we need to mix sound from the phone system (presented in mono RCA) and sound from the computer (for video clips) to the soundbar.
The reason for this is so that the presenter participants can hear responses from callers on the phone and sound from video clips play over the soundbar (so either the video or a caller would be heard). I'm sure we could probably somehow plug the phone system into the PC and mix internally, but people typically just use their laptop, so trying to deal with several OSes, OS versions, and hardware variations would be a nightmare. I n order to simplify things, we would prefer to mix externally.
Worst case, we could revert to simple analog audio from the laptop, but that would be another cable to plug-in and a different config for user to remember (as they normally just use HDMI)
Anyone got any suggestions?
Regards
Mark
Edited by mark_anderson_u - 8/21/12 at 3:16pm
post #2 of 3
I would use one of HDMI audio splitters to get audio out as analog stereo, then send it to analog mixer together with phone system output, then connect output from mixer to soundbar. If soundbar does not have analog inputs, replace it with a pair of active speakers. Get HDMI splitter on-line and the rest if equipment from your local pro music store.
post #3 of 3
Thanks AP1
Soundbar does have RCA input, so we're in luck
Regards
Mark
