I want to do about a 140 in screen. This particular wall is 88 inches high, which would leave me 20" of room from the top and bottom. My center channel is 11" high, which leaves 9" from the top of the wall. Is that enough, or am I going to have to go smaller with the screen? The ceiling is going to be painted Behr Silverscreen, and the walls are going to be very much darker, so I shouldn't get a whole lot of reflection. Also, the room is 100% light controlled.
The other compounding factor is the mounting height. I'll have to mount it in between the air return and the I-beam, which is 7 1/4" inches lower than the top of the screen wall. The lens would be about 12 feet away (although I can always go further back if need be; it just wouldn't look as good). Is that going to be a problem?
Thanks in advance.
Thanks in advance.
