AVS › AVS Forum › Display Devices › Display Calibration › Mistake that I hope won't affect the end result.
post #1 of 5
Hey guys!
Bought my dad a Panasonic 42 UT50 Plasma, excellent TV, great price. After the 100 hour Aging Process I Calibrated it using Calman and my x-Rite i1Display Pro. Great Results. Only later I discovered a big mistake.
I used D-Nice ST50 Calibration just as a guide to see how these new Panasonic Plasma were working, so when I went to the CMS, which my UT50 has in True Cinema Mode, I found out the Primary Luminance was higher than it should, I tried D-Nice setting of Color at 43, and that helped bring it all to standards. I continued the calibration to a very good end result.
Only later I noticed the ST-50 D-NICE calibrated didn't have a CMS, mine has, so I ended up using the Color Adjustment along with the CMS, something which probably wasn't needed if you have a complete CMS at your hands.
Do you think this usage of both Color and the CMS can affect the end result anyhow? The graph looks fine, so I wouldn't want to change it unless there's some obvious problem with using it this way.
Thank you guys! This forum has always been very helpful to me!
post #2 of 5
the UT50 has CMS when the more expensive ST50 doesn't?
Edited by simpson0086 - 8/21/12 at 8:59pm
post #3 of 5
Should be no harm in using the main color control if it helped to bring gamut more inline, many displays actually can be done in this manner and if you are not using the service menu some displays may require this for optimal results.
Jason
post #4 of 5
Either that or the calibrator didn't use the CMS for his ST-50, because he didn't specify any settings for the CMS.
The Brazilian UT50 is different from the American one, here we have Preset Game, Normal, Cinema and True Cinema, which is the only one with CMS, it doesn't have Color Temperature in this mode either.
So no harm doing that? Thank you for the information! It's really looking great after the calibration, I didn't try perfection, but everything is below human level of perception! Batman Dark Knight Looked beautiful on this TV
post #5 of 5
The North American UT-GT don't have a CMS. He lives in Brazil where they apparently get the EUR version.
Edited by rahzel - 8/22/12 at 8:19pm
