AVS › AVS Forum › Display Devices › Screens › DIY Screen Section › Paint vs Screen
Paint vs Screen
post #1 of 3
Just read an article on projectorcental.com. Had me thinking. I have an SI Gamma HD screen and I can see the texture on the screen when sitting close and from further away, its a little noticeable because I know its there. Paint should be the best way to go to get no texture in the image from a closer distance. I had the JVC RS55 and I am upgrading to a current model, to take advantage of the e-shift, I need to seat close to the screen. I don't want to see texture in the screen anymore, so am I going the right route? I know the Stewart Snomatte has the best image for what you project is what you get. A 100in 2.4:1 screen is about $2000 and to paint my wall and build a frame around it is only $200 at max.
Also, I'm moving into a house and having my theater room. I know if you paint the room all black, it improves the image like no other thing, but is there an alternative to having a black hole? I want the best possible image, so if I have to paint all black I will, but it will be a sacrifice.
post #2 of 3
Not at all certain the Snowmatte is "The best" but a light neutral Gray paint properly applied will offer you an exceptionally smooth screen. You'll want to spray on whatever choice you make, so consider this inexpensive HVLP Rig.
http://www.ebay.com/itm/GRACO-HV2900-39-CFM-450W-HVLP-House-Paint-Spray-Station-Machine-System-Painter-/230791007590#ht_4652wt_1140
Room surfaces need not be "Black" but the ceiling should be considerably darker than the walls in a room such as a dedicated Theater. Using a Mid-level Gray for walls (perhaps with a touch of Blue or Green mixed in) and a very dark Gray on the ceiling (both colors in Flat) is an attractive combination.
Very dark Flat Red for Walls and ultra dark Gray for Ceilings is another choice.
post #3 of 3
I knew you was gonna help. I should have said best neutral screen for a dark theater
  Back to Forum: DIY Screen Section
