AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › replacing 46inch hx800.....gt50 or e8000?
post #1 of 4
so my hx800 led is more than likely getting replaced rather than fixed, so I'm stuck on 3 TVs. Either I go with the newer hx850 led in the same size or I go plasma, and get either the gt50 or e8000. The reason I chose those is based on size, I can get away with a 50 or 51inch but anything bigger and my 52inch speakers will block them from certain angles which is why the vt50 is not on my list since the smallest is 55, unless I rework my speakers somehow that one won't work, all comments are appreciated
post #2 of 4
Unless you're not happy with LCD technology on your Sony then go for a Plasma, otherwise just get the new HX850.
post #3 of 4
So which plasma then
post #4 of 4
