AVS › AVS Forum › A/V Control & Automation › Remote Control Area › Harmony 900 or 1100 to be used with motorized projector screen
post #1 of 4
Hey Guys, just wondering if these remotes work with motorized projector screens? There are alot of no name screen manufacturers out there. In case it does work, is it possible to set it up even if the manufacturer is not on their lit or whatever?
Also, will it control the WD HD Live media streamer?
post #2 of 4
Yes. I control a Monoprice motorized projector screen with a Harmony 1100.
post #3 of 4
Nice, did you have to set it up automatically or was it in its Manufacturer list?
post #4 of 4
So long as a device is IR it will typically be controllable by the 1100 or 900. If you get an RF controlled screen which are the most popular you will need to do a little DIY tinkering to go from IR to RF.
http://www.avsforum.com/t/1300232/ir-control-for-rf-devices
If the monoprice one's are IR then there likely in the database already.
  Back to Forum: Remote Control Area
