AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Additional options on the AE-100
post #1 of 3
Hey Guys,
I saw a couple threads from Li On and many others about their settings on the AE-100. The basic ones (brightness, contrast, sharpness etc) are right there in the Picture menu.
And for R, G, B and any additional tweaks? What do I need to do to access them? Is there something I'm missing?
C
post #2 of 3
If you read a bit more into the threads or the owner's manual you should see that the RGB level adjustments are only available when a VGA input is used. I don't believe anyone has uncovered any hidden service menu type adjustments yet.
post #3 of 3
to get to the service menu go to the OSD and hold down the select button for about 3 seconds, there are other threads explaining the options you'll find there though. Good Luck.
This thread is locked
