AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Need help with layout suggestions.
post #1 of 5
I am taking my small theater and moving to a larger space that will be dedicated to it. I am stuck in a 12x13 box and moving to a 19x18 area. I have an issue with the HVAC running across the ceiling to where i am moving the theater. I cant decide which side to put the projector on. Can you guys give me some tips? Here are some pictures. The black room is the current theater. I am thinking of putting the screen on the wall with the framed jersey, or on the opposite side.
post #2 of 5
How big will the screen be in the new theater? By a new dedicated space, are you taking the drywall down and building it back up? If so, then moving the duct-work isn't a major job.
post #3 of 5
Current screen is 100". I will maybe go to 110" but probably not passed that. I mean dedicated meaning that will be its only purpose for the room. I doubt I will be taking down drywall. Plus the steel girder and hvac electrical is in that drop down.
post #4 of 5
Anyone have any suggestions?
post #5 of 5
If you can sketch out a plan in visio or on graph paper or something.. It would be easier to associate the pictures with the space. I see there is a door, so that is something that will need to be accounted for.
Tim
