AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Any 2D only projectors in $2500 range?
post #1 of 9
I am looking for a projector for my dedicated theater in my basement. Light will be completely controlled, and projector will be used for movies and TV (mostly football). The largest screen I have room for is 90 inches.
I don't care about 3D, but have found that all the projectors in that price range also do 3D. I was looking at the VPL-HW30ES. Can anyone recommend a non 3D projector below $3000? Are there any 2D only models available that do just as good 2D as the more expensive 3D models?
Any help is appreciated.
post #2 of 9
http://www.avsforum.com/t/1391476/coderguys-top-projector-picks
post #3 of 9
Thanks for the help. Picked up an 8700ub for $1600. Very excited.
post #4 of 9
Ltbbw, where did you get it from? Looking for the 8700ub also.
All I can find is around 2k for a new one.
post #5 of 9
Visual Apex sells manufacturer refurbished for that price with full 2 year warranty from Epson
Edited by MichaelG - 8/27/12 at 6:12am
post #6 of 9
Why was you looking at just non 3D? A RS40 and RS45 could be had for under $2500, much better 2D than the UB8700.
post #7 of 9
I cannot find any sources for RS45 for under $2500. Do you have any suggestions? Thanks.
post #8 of 9
I did purchase a factory refurb from visual apex. So far my experience with refurbs has been excellent. I have only found the RS40/45 for around $2900. They may be better than the 8700ub, and within my price range, but at $1300 less, I couldn't pass on the epson.
post #9 of 9
Avs had RS40s for $1800 and 45s for $2100. They were b-stocks. But new 45s can be found for $2450. But the Epson is very good also. Still a win
