http://news.cnet.com/8301-13645_3-10440755-47.html
http://sound-cards-review.toptenreviews.com/
http://compreviews.about.com/od/multimedia/tp/SoundCards.htm
It's amazing what Google can do for you.
FYFI, here's a thread posted on the main page of this forum that didn't even require a search to find it:
http://www.avsforum.com/t/1426304/audiophile-sound-from-htpc-sound-card-hdav1-3-or-is-there-another-option
To the OP - I don't recall whether you said what kind of audio you wanted to output to the amplifiers. If you plan on Blu-Ray playback then the Asus Xonar HDAV 1.3 Deluxe with the daughter card is the only choice I'm aware of that will decode HD audio and provide discrete analog outputs for each channel via gold plated RCA jacks. This card is no longer in production but can be found on ebay. Otherwise, you're limited to either Dolby Digital or DTS 5.1 audio, probably via 3.5mm mini jacks using some kind of dongle.
The main question is what kind of control is available for the outputs? Can you calibrate each output individually via an included app? Is some sort of bass management included? These are crucial for proper surround playback. If you only want stereo outputs then any of the cards linked above will probably do what you want since you can control the volume directly using the Windows volume control.
I did some searches for RMA and Lynx sound cards just to see what they offered and what kind of prices they go for. While price information is a bit sketchy (it was a quick search), it appears that most models are designed for mastering and mixing and not really consumer oriented. Prices were in the range of $500 and up.
FWIW, Emotiva has their UMC-1 preamp/processor on sale for $499, which would probably be a nice complement to your Emotiva amps.
Edited by captain_video - 8/27/12 at 5:46am
You've just confirmed what I've been saying all along. While there may be hardware out there that actually provides audiophile quality sound (which, in itself, is highly subjective), professional hardware is priced in the stratosphere and not affordable for most of us. An outboard preamp/processor would be more cost effective if you're looking for this level of sound quality. The links I provided above should satisfy anyone with less discriminating tastes and a more modest budget.Originally Posted by hdkhang
For those that harp on about how PCs are not for audio reproduction etc. Consider that a processor/avr is basically a very specialised PC. Also consider that all the music and movies you hear are mixed on PCs and that a properly designed PC does not have any of those unwanted qualities you speak of. I can put my ear up to my speaker and hear barely any noise coming out of it. Get a good PSU and motherboard and you are usually set.
