AVS › AVS Forum › Audio › Speakers › Speakers for my room size...nees some advice on a strange shape living room!!
post #1 of 9
Hey guys i need some advice. I wanted to get a 5.1 speaker system for my new apt living room. The space is a little strange with how narrow and long it is...maybe you can give me some ideas. I have a picture below.
Keep in mind that the room is 6'10" wide and 20' Long.
I was really looking to get some decent floor standers for the front but i am looking into some nicer bookshelves if you guys think the sound would be enough.
I'm trying to get the best for my money but i will pay a bit for some good quality stuff that i wont have to upgrade soon.
I look forward to your input!
post #2 of 9
OK i could not wait since i got an awesome deal
(2) RB-51 II Bookshelf Speakers
(1) RC-52 II Center Channel Speaker
(2) RS-42 II Surround Speakers
(1) Premier Acoustic PA-120 Subwoofer
Going to match them up with a denon avr-2112CI
All for under 1200!
post #3 of 9
6'10" wide? That's not a living room, that's a hallway!
post #4 of 9
Ya dude i now but its an awesome deal for the apt and its right by my job so it is what it is lol. I will deal with it and make it the best i can. How about the deal on the system im putting together though!
post #5 of 9
I think you need to put the surround speakers on the far corners. having them next to your head means that is all you are going to year with the mains and center being 10ft away!
post #6 of 9
All for under 1200!
Where is this deal? Sounds interesting!
post #7 of 9
All for under 1200!
Good stuff!! You're going to like the PA-120. I use to have a pair of them and still thing they are one of the best $ for $.
cheers
post #8 of 9
if the hard wood from the picture is true I would get a rug or some wall hangings to help absorb some sound... seeing as there is nothing else in the room
post #9 of 9
Ya i thought about the surround placement and i will be putting them in the far corners...they will be plenty loud!! As for the deal it was pretty much once in a life time. The website i got it from had a promocode that was supposed to work on only one item on the site but there was a glitch. I was able to use it on this speaker system and got it under cost. The guy from the site emailed me and honored it so i was really happy...cheapest setup of this kind i could have hoped to find!!
Ya i cant wait to use the pa-120 i hear awesome things about it. Do you think my placement is going to work nicely?
The room does have carpet so no worries :-)
  Back to Forum: Speakers
