AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Plasma To LED
Plasma To LED
post #1 of 5
I have a budget of just over 2000, I will be buying my TV from RC Willy or Magnolia (Best Buy).
I would like the biggest TV I can afford without sacrificing quality and what my stand can hold.
My current stand can handle a 60" display
I have a well lit that can also be blacked out.
I will be about 10' from the TV
I watch allot of TV, movies and sports
3D is not important but is nice to have (just in case)
My current plasma is a 42" Panny that is 2 years old.
I have no brand preference but have seen Samsung's and have like them.
I will be moving to Las Vegas is why no more plasma, don't need a hot running TV.
HD source is BR and Direct TV
Thank you for any advice you may have.
Don
post #2 of 5
Um thanks for all your help, decided to stay with plasma
post #3 of 5
post #4 of 5
many don't check the forums on the weekend... you could consider LED, but you'll potentially have to deal with issues with the technology like flashlighting/clouding, DSE and SOE. The "heater" issue with plasmas is overblown. a properly calibrated plasma will produce more heat than an equivalent size LED, but it's probably less head than a DVR or AVR.
unless your panny is broken, or produces unacceptable picture, why not stay with it?
Best,
jeff
post #5 of 5
If you do decide to switch to LED, I'd recommend the Sharp LC-60LE64OU for its above-average picture quality and colors, along with its low price compared to its competitors. This review covers the TV well: http://reviews.cnet.com/flat-panel-tvs/sharp-lc-60le640u/4505-6482_7-35123266.html
