AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Marantz SR6006 HDMI output not the same as input.
post #1 of 4
I currently have a Marantz SR6006 acting as a video switch for my computer.
I have noticed that white text on an orange background looked smeared.
When I connected the computer directly to the monitor with the HDMI cable, the image was clear.
I have attached photos of the screen for comparison.
Marantz SR6006.png 644k .png file
Direct Connection.png 646k .png file
I can't find a way to get the Marantz to pass the signal unmolested. Any clues?
post #2 of 4
Have you tried setting the "i/P Scaler" setting to OFF?
Also note that there is a dedicated thread for 6006 Owner's ---> http://www.avsforum.com/t/1334415/marantz-sr5006-marantz-sr6006-receiver-thread/0_100
post #3 of 4
Turning off the i/p Scaler did not fix the problem.
But, also in that menu is something called "Video Convert" (something I did not see last time I was looking). Turning this off fixed the problem.
A side affect of this is that the menu is no longer overlaid over a dimmed picture, but instead on a black screen. This is easier to live with than the smeared text.
Thank you.
post #4 of 4
The Video Convert setting is only required when converting an analog input source ---> HDMI; however, as you learned disabling it disables the GUI overlay capability.
