Just bout a new 64" samsung tv. was looking to buy my first surround sound system. People have been telling me to buy an Onkyo what are your guys thoughts? and what is a good model? And is it worth it to buy the home theater sets or buy it all separate? will be used for tv, movies and for hosting guests with music playing.
Featured Stories
Topics Discussed
- itemDenon AVR 1613 Receiver
- itemDenon AVR3312CI Receiver
- itemDenon AVR 891 Receiver
- brandONKYO
- itemOnkyo TX NR818
- itemPs3
- categoryReceivers Amplifiers
- brandSamsung
- itemSamsung PN64D8000 64 Inch 1080p 600Hz 3D Plasma TV 2011 MODEL
- categorySpeaker Systems
Related Forum Threads
- ONKYO HT-S7409 keeping receiver and Upgrading speakers Last post on 9/4/12 at 5:25pm in Home Theater In A Box
- Yamaha V473 or Denon 1613? (I know the wrong section...) Last post on 1/11/13 at 10:19am in Speakers
- good set up?? Last post on 1/10/13 at 10:25am in Speakers
- First Time Sub Owner - Quick Help On Setup Last post on 1/13/13 at 4:30pm in Subwoofers, Bass, and Transducers
- ext amp question Last post on 1/2/13 at 8:59am in Receivers, Amps, and Processors
Related Articles
What Surround Sound Configuration Is Right For You?
Edited on 11/1/12
- 10 Video Games To Show Off Your Home Theater
Edited on 9/14/12- Denon 2011 and 2012 AVR FAQ, Setup, and Troubleshooting Guide
Edited on 9/13/12Related Reviews
Looking at buying a Receiver
Gear mentioned in this thread:
post #2 of 558/26/12 at 1:52am- afrogt
- Trader Feedback: 0
- offline
- 19,909 Posts. Joined 7/2003
- Select All Posts By This User
post #3 of 558/26/12 at 5:47am- joeyvaz
- offline
- 506 Posts. Joined 10/2003
I agree with AFROGT with the exception of reliability. ALL brands have issues with the receivers due to the complexity they bring to the table. I've had nothing but exceptional results with my last three Onkyo receivers. All with the last 4 Pioneers and 2 Yamahas (I upgrade every 12-18 months)
With that said, Onkyo gives some of the best bang for the buck receivers right now. I love the way they sound with my Emotiva speakers. I love the way Pioneer pairs with my Def Tech setup in my main HT.
I would advise you to come up with a budget (receiver, speakers, and sub) decide if you prefer towers or book shlef speakers (room size MAY dictate which route you should go) and then we can give you some suggestions. Nice thing about going individual components versus a HTIB (home theater in a box) is that if you ever want to upgrade the receiver, sub, or speakers in the future, it will be easier to do because the other components are of better quality. I've learned from being in this hobby 25 years or so, once you're in, it's very addicting. Of all the hobbies I've had, this is the only one that I've never gotten tired of. I don't think I ever will.post #4 of 558/26/12 at 8:38am- jpcamaro70
- offline
- 208 Posts. Joined 5/2012
Everyone will have different opinions regarding the AVR's. I prefer Denon, they've done very well by me, but i've also used onkyo without any problems.
The biggest mistake i made was going HTIB (home theatre in box) to try and save money. Yes, you'll spend more on separates, but what a difference in sound.The room is probably 15x15. To be honest I am. It looking to have a movie theater replica sound. I like good bass and other than that just something that spuds good and can run my xbox. Ps3 cable box and anything else since my tv only has 3 hdmi I'd rather use te receiver to plug all my devices in to and just use 1 hdmi on the tv.post #6 of 558/26/12 at 7:15pmFigure out your budget, what you want in a receiver, what kind of speakers you want to fit your space, bass wants and then come ask us. All the mainstream receivers have good options. Speakers are easy to come by for any budget, though you'll get a lot more if you spend at least a few hundred dollars, better yet at least a grand. Personally, I recommend starting out with a 3.0 setup to get started, or better yet 3.1 if the budget allows. Upgrading to .2 or more and getting surrounds are very easy to integrate into any system, low end all the way to no holds barred budget.
butter and jelly please.post #8 of 558/27/12 at 3:27pmQuote:
See if you can find a denon 3312 within your budget. I would go no less than an 818, if you want onkyo, but that is a couple hundred above budget. Or get the best Yamaha you can with your budget. Start looking at last years models to get the best deal. I am up in the air about pioneer. The limited listening time I've had with any pioneer was underwhelming in very bad environments. But out of all these mentioned, perhaps try and get a Yamaha 1010.
butter and jelly please.post #10 of 558/27/12 at 6:42pmpost #11 of 558/28/12 at 4:50am- jpcamaro70
- offline
Buy a good reciever that has just what you need, don't spend more to have unnecessary stuff, and spend the rest on speakers. Good speakers are the best way to even come close to movie theatre sound.
The Onkyo looks good. You can get the Denon 1613 for under 400. Then spend every other penny on speakers. Since you want good bass, expect to put a lot towards the powered sub.post #12 of 558/28/12 at 6:15am- jdsmoothie
- AVS Addicted Member
- offline
- 34,469 Posts. Joined 9/2007
This is the reverse of what is generally recommended (ie. better to have a lower end AVR with better quality speakers) as the audio comes from the speakers. The Onkyo 515 uses the lowest version of Audyssey 2EQ, so you're better served with a lower level Denon (eg. 1612 or 1613) which has 2x the speaker filters as does 2EQ and can also EQ the subwoofer which 2EQ cannot do.post #13 of 558/28/12 at 9:10am- KidHorn
- Trader Feedback: +1
- offline
- 1,817 Posts. Joined 11/2003
If you want good bass, get this..
http://www.outlawaudio.com/products/lfmEX.html
It's on sale until sept 4th for $599 with free shipping. It's an awesome sub for the price.
I agree you should spend much more on speakers than the receiver. All receivers more or less sound the same. Speakers don't. Having said that, whatever receiver you buy should have room correction software, Audyssey for Onkyo, Marantz and Denon. YPAO for yamaha. MCACC for pioneer. Audyssey is better than the others at the higher end (XT and XT32).I was just looking on the main page article about the surround sound. what kind of setup is recommended for a 15x15 room. its probably between 12-15' but for argument sake. should i go 2.1, 5.1 or 7.2? Wouldnt that be the best way to figure out a receiver? I guess I just want a nice setup that I can use 1 hdmi out on my tv and the receiver will do the rest for my devices. also i see some of the onkyo's now are ready for the 4k. that would be nice to have a somewhat future proof receiver.
this all being said i had a samsung powerbar that i got with my tv before returning it that to me sounded good and that thing is 300 brand new. I would prefer like i said to have it all for about 5-600. I can upgrade later if need be but i am using sony speakers a friend had from his SS system that he spent a total of 300 on and a few little cheap JL speakers and to me it doesnt even sound bad.
Maybe I dont know much about audio but i always thought denon was cheap quality and onkyo was the king...post #15 of 558/29/12 at 4:51am- jdsmoothie
- offline
It's actually the reverse in reference to both audio fidelity and QC on the lower/mid level models .... as Onkyo 717 and lower only use the lowest level Audyssey 2EQ which cannot EQ a sub, while all but the lowest Denon model (1513) use at least Audyssey MultEQ which has 2x the number of speaker filter resolution than does 2EQ and can also EQ the sub.
Also whether you expand from 5.1 to 7.1 depends on whether you are adding front heights, front wides, or surround back speakers and if surround backs, whether there is sufficient room behind the main listening position.post #17 of 558/29/12 at 12:13pm- jdsmoothie
- offline
With as frequent as the HDMI specification is changing (and whether it will continue at all), it's tough to say an AVR purchased today will still be usable 5 years down the road. Your best bet is to pick up one of last year's models on clearance. Better yet, you may be able to get a refurbished unit for even less. Accessories4Less is an authorized Denon and Onkyo refurb reseller and most units come with a 1 year warranty.
http://www.accessories4less.com/make-a-store/item/DENAVR1612/DENON-AVR-1612-5.1-Channel-A/V-Home-Theater-Receiver/1.html
http://www.accessories4less.com/make-a-store/item/ONKTXNR515/Onkyo-TX-NR515-7.2-Channel-Network-A/V-Receiver/1.htmlpost #18 of 558/29/12 at 12:33pmQuote:
If the dam don't break and the creek don't rise, you should be good for a couple more weeks.
As long as you don't go and change any of your gear, the gear will be good until the wheels fall of but if the formats change and obsolete your DSP, then you're SOL. Future casting here, I suspect that soon, rationally, Blu-ray will be obsoleted by SS chip technology. You'll buy movie content on a thumb drive. Soon there will be a cross over as the price of SS, flash memory chip technology overtakes the likes of Blu-ray. Maybe one day you'll just plug into the wall and download content from the web. Oh, wait, that's already happening. The point, even the days of Blu-ray are numbered. The clock is already ticking. Tick-tock Blu-ray.
The best way I can suggest to future proof your 5.1 system, is to buy "DECENT" speakers and marry them with a sound system consisting of separates. The Amp will be with you always or until it goes up in smoke as in; that's not good. As to the pre-pro, one can regularly replace the unit as one finds need, making the swap out cheaper to keep one's self current as pre-pros are rudely obsoleted out from under their poor, unsuspecting, innocent, I don't want this to happen, feet.
The above is the long way of saying, no matter what one chooses to do, manufactures are going make sure to hose everybody equally and there's not a darn thing anybody can do to stop the reality of the issue.
Oh boo-hoo!
-If it were you guys would you buy the denon 1612, 1613 or the Onkyo NR414, NR515 or NR616? My gut tells me the NR515 but i am a newb. guess the Onkyo brand name has me leaning that way mostly because it seems to offer more.
Or am I just best off keeping my current technics receiver/sony speaker and sub setup for a few months and wait for a great deal around the holidays?post #20 of 558/29/12 at 1:09pm- jdsmoothie
- offline
post #21 of 558/29/12 at 2:39pmQuote:Originally Posted by djtoodles
Denon. Even though I like and prefer onkyo overall, denon is a better choice with lower tier models. Onkyo isn't a good choice unless you jump up to at least the 818 or higher model. Yamaha is a good brand also with any budget.
butter and jelly please.post #23 of 559/2/12 at 5:50pm- jdsmoothie
- offline
post #25 of 559/2/12 at 7:56pmDenon or Yamaha. I considered Yamaha but really wanted bass eq and it surpassed my expectations. I had a hard time believing bass could get a lot better because of some fancy schmancy algorithms with room correction but it does help. Why don't you research Yamaha some and figure if you could do without audyssey in favor of ypao.
butter and jelly please.post #26 of 559/3/12 at 5:39am- jdsmoothie
- offline
post #27 of 559/3/12 at 11:28amPukemon and Joeyvaz - wanted to get your advice on the following: I'm planning on purchasing a Panny VT 50 plasma and wanted to set up a home theater system with Def Tech 8060 floor speakers that have built in subs, 8060 center channel also with built in subwoofer along with 8040 rear speakers. Which of the following receivers would you both recommend to power the system:
Pioneer Elite SC-65
Denon 3313
Onkyo 818
I am very new at this and just started doing a bunch of research and any advice you both can give me would be great.post #29 of 559/3/12 at 1:53pm- jdsmoothie
- offline
post #30 of 559/3/12 at 2:05pmQuote:Originally Posted by STEVEIB7
Pioneer Elite SC-65
Denon 3313
Onkyo 818
Are those speakers with powered woofers or passive? If they don't have their own amp built in, chances are you're better off getting an external amp and using an avr as a pre pro. I could be wrong though. Might want somebody with more experience to give a recommendation. But for an answer, if I was in the market for a comprehensive eq, I'd choose the 818 or pioneer. If music was my first priority, the denon. All are good choices though. I ended up passing on the 818 and got an onkyo 3009 for the better amp section.
butter and jelly please.Return HomeBack to Forum: Receivers, Amps, and Processors- Looking at buying a Receiver
Currently, there are 1422 Active Users
(229 Members and 1193 Guests)
Recent Discussions
- › Official Samsung PNxxF8500 Series Discussion Thread [No Street... 3 seconds ago
- › Review: Your Sister's Sister 36 seconds ago
- › DIY Unusual Shape Subwoofer Question??? 50 seconds ago
- › 'Revolution' on NBC 2 minutes ago
- › Official Vizio M-Series Razor Mxx1i thread 3 minutes ago
- › Now Showing - What We Watched 3 minutes ago
- › Simplified REW Setup and Use (USB Mic & HDMI Connection) Including... 3 minutes ago
- › Verizon FiOS HDTV 3 minutes ago
- › Anyone here using an Emotiva UMC-200? What are your thoughts? 5 minutes ago
- › Anthem MRX Receivers - 300, 500, 700 Owners Thread & Tweaking Guide 5 minutes ago
View: New Posts | All Discussions
Recent Reviews
- › Marantz AV8801 by zuluwalker
- › VIZIO 55 inch Class LED - M3D550KDE by indept
- › Optoma GT700 3D Game Time Projector by paul65000
- › InFocus X1A DLP Multimedia Video Projector by coastercard
- › BenQ W1070 1080P 3D Projector by arjjr
- › Epson PowerLite Home Cinema 8350 by Natros
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
View: More Reviews
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
View: New Articles | All Articles
Home | Reviews | Forums | Articles | My Profile
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
![Samsung PN64D8000 64-Inch 1080p 600Hz 3D Plasma TV [2011 MODEL]](http://cdn.avsforum.com/1/1c/50x50px-ZC-1c92d0f5_B004RTE5BA-31bAG72Yj6L.jpeg)
