I've decided to spend some money and upgrade my home theater setup. I have a room that's 15' x 14' and 12' ceilings.
I'm in NYC and finding a place that will give me some attention and answer my questions seems impossible. The only way I've been able to research is to walk into best buy / magnolia and play with the equipment on display my self.
Starting with things I've narrowed down after some research and in-store demos.
- I like the B&W 600 series, they sound great and fit the budget I'm aiming for.
- I like Marantz receivers but Denon these days seems like the better choice for similar/same thing.
So here's kind of what I had in mind:
Denon AVR-3313CI Receiver
B&W HTM61 For Center
B&W 683 for Fronts.
B&W 685 for Rears
B&W ASW 610XP for the sub.
Now my only concern is that I've looked at a few 683's in store and all the aluminium woofers are distorted with finger print size dents, even the ones that have the grills on. I'm almost certain the finger dents aren't part of the design so are they just really easy to permanently distort if touched?
I'm very concerned by this, that someone might touch my speakers by accident and then those dents would bother me forever. So I was thinking about getting the 684s, which are more practically sized, and considering I live in NYC I can't really crank my speakers too loud anyway. The problem is do I then change the centers and rears for their small counterparts, is there any advantage of still keeping the higher end rears and centers. I also think the smaller size are better looking / more practically sized but either way I can make it work.
Looking for advice from the masses, particularly those who own this receiver and/or speaker series.
Tank
B&W 683 for Fronts.
B&W 685 for Rears
Tank
