Featured Stories
Topics Discussed
Related Forum Threads
- Assistance with screen size Last post on 12/5/12 at 11:16am in Screens
- illogical Home Theater Last post on 10/15/12 at 5:44pm in Dedicated Theater Design & Construction
- JBL SYNTHESIS LS Series SPEAKERS YES or NO?! Last post on 3/12/13 at 11:35am in Speakers
- Help me out, please... Last post on 8/12/12 at 11:57am in General Home Theater & Media/Game Rooms
- Need a 7.1 AVR recommendation, $500-$750 Last post on 8/8/12 at 8:27am in Receivers, Amps, and Processors
Related Articles
What Surround Sound Configuration Is Right For You?
Edited on 11/1/12
Related Reviews
Center channel recommendations
Gear mentioned in this thread:
- flyng_fool
- Trader Feedback: 0
- offline
- 3,044 Posts. Joined 8/2009
- Select All Posts By This User
http://www.amazon.com/Definitive-Technology-ProMonitor-Bookshelf-Speaker/dp/B000TD6QLK
- logan115
- offline
- 66 Posts. Joined 12/2010
- flyng_fool
- offline
http://forum.blu-ray.com/showthread.php?t=89614
- Kal Rubinson
- offline
- 27,487 Posts. Joined 3/2004
Not really. Any horizontal array will have lobing problems whether it is an MTM or an MT bookshelf design.
- rick240
- Upgrade Addict
- offline
- 3,386 Posts. Joined 10/2004
...but if I've understood your, and others, comments correctly...
...the MT will have lobing only in the crossover region
...whereas the MTM will have lobing in the entire range of the two Ms plus the crossover range
- flyng_fool
- offline
- Kal Rubinson
- offline
Exactly.
http://www.audioholics.com/education/loudspeaker-basics/vertical-vs-horizontal-speaker-designs
In theory. However, the lobing is dependent on driver spacing and only significant when the driver spacing exceeds 1 or 1/2 wavelength (depending on who you believe). Thus, "the two Ms" will have problems only at the upper end of their ranges and not at the lower end. So, it comes out to the same issue: Major lobing problems are generally in the crossover range, regardless of the number of drivers.
- commsysman
- Trader Feedback: +1
- offline
- 3,527 Posts. Joined 12/2007
- flyng_fool
- offline
- Kal Rubinson
- offline
- flyng_fool
- offline
- flyng_fool
- offline
- HighEndAV
- offline
- 12 Posts. Joined 8/2012
- flyng_fool
- offline
- Kal Rubinson
- offline
- flyng_fool
- offline
- Kal Rubinson
- offline
The point I was making is that "if the tweeter radiates equally in all directions" it will not resolve the lobing problems associated with horizontally arrayed drivers. In fact, controlled dispersion is possible way to ameliorate the problems.
- Jay1
- No hype needed
- offline
- 3,378 Posts. Joined 8/2002
- Kal Rubinson
- offline
Even then, it is still compromise. You are not completely on axis with the tweeter, and if you are then other seats will not be. More importantly, you lose sensitivity and gain distortion in a TM design over an MTM design. It is compromise no matter what unless you have a transparent screen with speakers exactly aligned, and usually those speakers will have a small line array (MTMMM) or need to be a well designed speaker to not run into compression/distortion at reference levels.
- flyng_fool
- offline
But I very much agree with you vis a vis the directivity and controlled dispersion.
- rick240
- Upgrade Addict
- offline
As I understand laying the speaker horizontally doesn't create lobing, it just changes it from being in the vertical direction to the horizontal direction. Lobing happens because there are two source producing sound in the same frequency range and the two waves combine either cancelling or adding causing audible effects.
The point is that most people sit at the same vertical level when watching a movie but are horizontally dispersed in front of the screen.
Hence - vertical lobing is a non issue - horizontal lobing can be an issue with wide horizontal dispersion of people and/or particular speaker designs.
- hwdoughty
- offline
- 3 Posts. Joined 8/2012
- Jay1
- No hype needed
- offline
If you tilt the speaker back, you will be vertically on axis. Horizontally, a vertical TM configuration will have very wide dispersion at all frequencies but the very top of the tweeters response, which has nothing to do with vocal intelligibility. There are plenty of large woofer, high sensitivity 2-way designs available. A perfect example of this setup idea is the Klipsch Heresy
A smaller, cheaper option would be a Chase SHO-10 with a custom stand.
http://www.gwizpro.com/stands/proddetail.php?prod=SCStands
Fair enough, many home theater setups will still have seats that could be easily off axis both vertically and horizontally even with an angled speaker. There are definitely some well designed 2-way speakers, some may be rather sensitive as well. However, using the same drivers in an MTM you will still have lower distortion especially in the vocal range that the midranges would be handling.
- Center channel recommendations
Recent Discussions
- › The Room Mclaren 14 seconds ago
- › 4k by 2k or Quad HD...lots of rumors? thoughts? 32 seconds ago
- › Panasonic ST60 Deals 55 seconds ago
- › Triad Owner's Thread 1 minute ago
- › Official Panasonic VT60/VT65 Series Discussion Thread [No Street... 1 minute ago
- › F8500.. OR .. ZT60 ????? 2 minutes ago
- › In-Wall Sub Question? 3 minutes ago
- › Official Sony XBR-55X900A / XBR-65X900A Owner's Thread 3 minutes ago
- › Hot Off The Press: The Latest TV News and Information 3 minutes ago
- › DIY Compare to ID Companies? 3 minutes ago
Recent Reviews
- › VIZIO 55 inch Class LED - M3D550KDE by indept
- › Optoma GT700 3D Game Time Projector by paul65000
- › InFocus X1A DLP Multimedia Video Projector by coastercard
- › BenQ W1070 1080P 3D Projector by arjjr
- › Epson PowerLite Home Cinema 8350 by Natros
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
- › Epson 5020UB Powerlite Home Cinema 3D Front Projector by DDT0C
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
