I have started to explore Magix Pro X4 a litte bit more. Two reasons for that:
- it is another s3D editing tool
- it offers the possibility to build a 3D-Blu-ray with menus.
Genrally spoken, it is a young product - what means that it has potential for improvement, even if I think that it is a great product today too.
The 3D-BD generation suffers from an error in the Mainconcept MVC encoder, since the encoding breaks down a lot of time. Here Magix waits for an update from its supplier Mainconcept.
https://support2.magix.com/customer/de/node/187968
Beside that, I have been successfull to generate a first 3D-BD with menus. The menus are 2D only, what means that your 3D HDTV will have to switch between 2D and 3D during presenation - what seems to work fine for the first time you do that, but I have seen some issues when going back from the video to the menu - where you switch back from 3D to 2D: here my 3D-HDTV shows some flickering, what does not go away any more (until I stop the 3D-BD).
But beside that I see a product with some potential, that can become even better.
