Mr.Tim's 15x27 Theater
post #1 of 340
Many years in the making, the theater is finally beginning to look like something. When I built my house a few years ago, I accommodated for step-down seating.
Here's the details:
Construction:
5/8"+1/2" GWB with Green Glue
RSIC-1 and channel (both sides) between theater and adjacent mechanical room, double stud walls elsewhere
Pink fluffy fiberglass throughout, except brown death in mechanical room wall
Risers are 2x6 w/ 3/4" advantech (3/4"+3/8" on upper riser)
Electrical:
4x20A to rack
1x15A and 1x20A for lighting
2x Lutron GRX-3104
  • Zone 1- 3 recessed lights in adjacent walkway
  • Zone 2- 4 step lights
  • Zone 3- 4 recessed lights above screen
  • Zone 4- 6 recessed lights above seating
  • Zone 5- 4 recessed lights above rear "bar area"
  • Zone 6- LED tray lighting
  • Zone 7- Lights for speakers behind AT screen (? maybe)
  • Zone 8- LED edge lighting along screen (? maybe)
Audio:
Onkyo NR709
2x Buttkicker 1000W amps
Mains- 3x Stentorian (to be built, I have the drivers)
Surrounds- 4x Sten II (ditto)
2x Buttkicker in riser
2x Cinema F-20 (1 built, need to build at least 1 more)
1x 15" ported sub (see my sig)
12ga to all subs and buttkickers (wired for 6)
14ga to mains and surrounds
Video:
Projector TBD (glad I didn't buy one 3 years ago!)
HTPC
Cheap Blu-Ray player
Tim
post #2 of 340
Plan:
Stage:
post #3 of 340
Where I started:
Where I am today:
post #4 of 340
WHOO! You've got some sweet dimensions to work with. Your blueprints look intriguing.
Am I seeing an acoustically transparent screen with a chamber for speakers behind it? I don't see it in the first pic, but it looks like that might be the second pic.
Spoken as the guy who just finished his theater this past weekend... "Soldier, I wish you well."
post #5 of 340
Ooops. I commented too soon. You're still unfolding your story in pictures.
<--- Shutting up.
post #6 of 340
There's about 2 feet of space behind the AT screen. I furred out the front wall 3-1/2" and installed Roxul Safe'n'Sound across the front. The corners will be pink (or white, in my case) fluffy fiberglass bass traps; 2 layers of 6" with air space behind.
Thanks for the well wishes, I have been working on this a long time and finally feel comfortable starting a thread. I think I may be done before the "old thread warning" appears smile.gif
This is what it looks like:
Tim
post #7 of 340
Brother, I totally understand that. I also waited to start my thread until I was sure my start-and-stop build was more started than stopped.
At that point, I had internalized so much heartbreak I didn't wan't to go back relive it all in a forum. And then, you see so many pics of OMFG!-quality builds by guys spending $100K, and you think "Nobody is going to care about my little shoebox build."
Yours is definitely off to a really good start. Keep on, keepin' on.
post #8 of 340
Tim, your contributions to this forum have always been precise and insightful. I've been waiting for you to start this thread for a while now, because I knew it would be a good one. (No pressure wink.gif )
The plans and progress look great so far - how about a list of equipment?
Fred
post #9 of 340
Fred
Thanks for the kind words, Fred. I have a lot of photos of construction, but I'll be darned if I know where they are. I just realized the 16gb card from my Nikon is MIA, I suspect there are some photos on there. The mightiest of plans and ideas succumbed to the reality of budget. I had to make some compromises in design and material.
I had planned on a much more intricate (read:wood) ceiling, but in the end drywall and spackle is a lot cheaper.
My soffits were made from left over framing material, which wasn't the greatest (actually, it was as crooked as a rattlesnake, but it was free):
About 15mins with the power planer and a straightedge and I had a flat surface. It was interesting to see the deflection in the joists due to the dead load above. The ceiling actually dips down a bit, but I made the soffits straight.
Front soffit was a lot easier!
Some people don't like metal, but I love it. Always straight. However, I always use 20ga. I refuse to use 25ga for anything. In a pinch I will pick up one or two 25ga on a Sunday if I need them.. I always regret it.
Tim
post #10 of 340
Good to see your build thread. You've always given great advice on this forum. I was going to make a comment on how you would probably pass me up in the progress department, but alas you already have. frown.gif
post #11 of 340
I had about a 5 year head start smile.gif I wish could say everything went as planned, but things change and many things returned to the drawing board. At one point I just threw the board out the window and winged it.
So many pipes/wires/ducts to work around.. Add in a budget and all heck breaks loose.
Still a bit to go with construction, so hopefully I can help somebody out.. somewhere.. with something I do.
Tim
post #12 of 340
Installed CHDK on my cheapo Powershot A560, pretty cool! Wish I could take credit for this awesome idea, but I gotta give props to jdanforth, whose idea I have blatantly stolen smile.gif Like I hope to have, he has two Cinema F-20s in his room. Check out his thread here. His time lapse vids are sweet.
Without further ado.. I give you..
post #13 of 340
Whoo! I've been waiting for you to post a build thread for awhile now after all of the great advice you gave me. Keep up the good work!
In regards to putting lights behind your AT screen, I think that that would look awesome. Some kind of opening video (think IMAX) that you could load into your HTPC and play before a movie would be so cool. Maybe even some track lights installed in front of the speakers on the stage that shine up on them?
post #14 of 340
It's hard to believe your space is 15 x 27. It looks HUGE. Great use of the space and the layout is GREAT!
post #15 of 340
Really like the tiered soffits over the riser. Looks really sharp.
post #16 of 340
What is brown death? Rock wool?
post #17 of 340
I wasn't going to do it, but I have the extra zones, so it is an idea (unless somebody has a better one!). Relatively easy to implement at this point if I use incandescent bulbs.
Thanks! The room measures 27'-1" from the rear wall to the front wall. I furred both of them out with 3-1/2" studs spaced 1" off the drywall, leaving 26'-4". The seating and screen wall portions of the room are 12'-8" wide. The walkway adds another 3'-3". The ceiling is about 9'-6" at it's highest point.
Due to mechanicals, I soffited down to 7' at the entry door. Lucky me, 7' is the minimum ceiling height to meet code. I'd like to be able to say I planned it that way, but I had to use a shoe horn just to get that height. The upside is you enter into this small space, but when you step down into the theater, the whole place just opens up.
They're still a work in progress. I have to finish framing the "frame" for my screen. I've been trying to figure out the best way to do it.. I would think it would be easy, but I keep changing my mind.
Yes, rock wool. The real stuff. Safe'n'sound is nothing like what I put in the mechanical room walls. I could lay safe'n'sound batts two deep on the floor and take a nap in it. I will never use rock wool again now that I've discovered safe'n'sound.
Tim
post #18 of 340
Making the stage..
I chose the classic stage design that many of us have chosen. Not sure who pioneered this design (Sunset Cinema?), but it's classy.
Scribed the lines:
Filled with sand (small openings stuffed with fiberglass):
Covered with Tyvek:
Deck:
Install the risers (3/8" ply):
Deck again:
I did the risers before the second layer of decking for a specific reason. No matter how good you are with a jig saw, the plywood never comes out perfect when you cut an arc.
The 3/8" plywood on the riser smooths out all the zigs and zags. After I installed the second layer of OSB I used a router with a flush trim bit to make a smooth arc.
Tim
post #19 of 340
Looking good Mr. Tim! I'm excited to see this one - as aaustin said above, I have appreciated your advice in my build very much!
post #20 of 340
Ok, $20 to the first guy to spot a code violation in Mr.Tim's theater.
Just kidding, looking good. Keep it up.
post #21 of 340
Hahaha man I hope there's no violations in these photos!
First rule of inspection: you don't have to be right, you have to be reasonable! smile.gif
post #22 of 340
It's 8:30p and I think I'm done spackling for the day.
Went through another 5 gallons. Everything has 2 coats and about 90% has a third.
I'll finish up the third coat tomorrow AM then off to big orange to get a new miter saw, some 3/4 MDF and some 3/4 birch plywood.
Hopefully I can get everything primed tomorrow.. or at least most of it.
Made a call to the supplier and it looks like my new CAC air handler and condenser will be here some time after Labor Day. Sure wish I had installed that first, it's got to be 90%+ humidity down there.
Tim
Edited by Mr.Tim - 8/28/12 at 5:48pm
post #23 of 340
High humidity means the mud and spackle will take forever to dry.
post #24 of 340
WOW! I'm glad I came across your thread Tim. I have been waiting to see your thread for a long time (no pressure).
What are you doing for HVAC in your theater?
Nick
post #25 of 340
Yeah, it does take a while. I'd like to say I would move faster if it dried faster... But I'd be lying. I can only do so much without having to take a break. My elbow has been joined by my shoulder in a symphony of pain.
Luckily the room is big enough that I can keep moving without much hassle. The third coat is pretty thin, so even with high humidity it dries ok. I have a fan going.
Nick
For starters I'm putting a 3-zone system in the house. The basement will have it's own zone with two thermostats. One tstat in the theater and one in the other part of the basement. The AC will come on if either tstat calls.
The theater ductwork has been sized equivalent to the rest of the basement. It's been so long I don't remember what the CFM numbers are (60, I think? I can push more if I have to), but it should meet NC17. A 5" supply with a 2' 2-slot diffuser and a 6" return with an 8x8 filter grill.
Additionally I have wired for a mini-split, as the CAC will not support a full load of people in the theater. I didn't want to be dumping a ton of CFMs in the empty theater with the CAC when the rest of the basement was calling. Th theater would be like 50 degrees. The CAC should handle 3 people in the theater (which will be 90% of the time). My equipment is not in the theater.
Tim
Edited by Mr.Tim - 8/29/12 at 4:03am
post #26 of 340
Does anybody know of a flush mount IR emitter? THe only thing I can find is this:
Do they not make one that you can drill a round hole and push it in (like most of the receivers)?
Tim
post #27 of 340
Tim
Do they still have issues with emitters not being directly attached to the components IR window? I would be interested to know if that style emitter works.
post #28 of 340
Sigh. Even if they made one and it cost a dollar, it still wouldn't work with my UVerse remote. Profanity, profanity, profanity.
post #29 of 340
A lot of Microsmith users report success controlling their UVerse remotes. I don't have UVerse, but I love my Hot Link pro set up.
post #30 of 340
Color... color.. and color.
Need thoughts on paint scheme. So far I have the following:
Wainscot: black (General Finishes black)
Upper Walls: brown (Behr Mocha Latte)
Soffits: ??
Ceiling: ??
Absorption panels: red (to match my seats)
I had originally planned on black ceilings, but wondering if a dark blue might be cooler? I will have red LED uplighting in the trays.. Don't know if it will work better with blue or black ceiling?
Should I paint the soffits brown too? Or black?
I guess it really depends on what color I paint the ceiling.
I'm not the best at picking out colors..
Tim
