The way I approached picking colors in my room was having the ceiling one color, the bottom of the wall and the soffits one color, and then the space between the bottom part and the soffits one color. I went with black for the ceiling, gray for the bottom walls and soffits, and dark red in the middle.
I like to say that the middle color is kind of the odd one out (red in my case, mocha in yours). Then the other two colors are a little more similar.
I think that a dark blue ceiling, black bottoms and soffit, and the mocha in the middle may work well in your room. The black might be a little harsh for the brown though, so you could go wit a dark gray.
Personally, I don't know how well the red panels will fit in on the walls. I'd think that they may look kind of out of place. I think that a gray color may be better for them. The red chairs would look nice next to the brown and gray in the room.
It's just my opinion though. You may feel differently.
By the way, are you not going to use RGB LED strips?
