We just installed our Epson 3010 this week and LOVE it - it's been fantastic so far.
Only issue we are having is that when anyone walks around the floor immediately above where the projector is mounted, it vibrates and shakes the picture quite a bit. The room above the projector is the kitchen, so it definitely will see it's fair share of activity.
I'm trying to come up with a solution to eliminate the vibration. We are using this mount:
http://www.amazon.com/Projector-Gear-Projector-Ceiling-PowerLite-Extension/dp/B006HYMH7W/ref=sr_1_6?ie=UTF8&qid=1346093134&sr=8-6&keywords=epson+3010+ceiling+mount
And we do use the 13" extension due to an overhang above the screen. I believe the extension does add to the wobbly-ness. I contacted the manufacturer of the product, but they were not much help. Their response was "if the ceiling moves, it will vibrate - not much you can do."
Toying with the idea of purchasing the same type of brackets one uses when hanging a garage door opener and adding them for more stability. Might anyone have other ideas?
