Hi there,
I just ordered a Mitsubishi HC6800 to go in a non-dedicated Home Theater. The room doubles as a spare bedroom, has white walls and ceiling, and dark brown carpet. There are two South facing windows, and the 'door' is an approximately 4' wide opening facing the wall the screen will sit.
I can use blackout curtains etc to control the light from the windows and doorway, but I don't think I will have a completely controlled environment.
Spent the last couple of days reading he laminates thread and was fairly set on doing a WilsonArt Fashion Grey screen. I only got to page 30 or so, and then started reading about Silver Fire v2, no I don't know what I want to do.
I want to do a 2.35:1 screen approximately 96" wide, I will then use some form of masking system for 16:9 material.
I have never spray painted but I am willing to buy a gun if that is the route I decide to go down.
I'm guessing most people will suggest the paint. I think that is what I'd like to do, I was thinking of a SF v2.5 in 3.0.
I own the house and I am happy to paint the wall and then put up a border, or is it better to buy a Substrate and paint that?
Help!!!
Help!!!
Clarify you actual desired screen size / dimensions.
