Originally Posted by edorr
The modded Oppo takes the CBIII out of the equation completely. I run digital into my Trinnov directly from the Oppo S/PDIF outputs. The Oppo does the decoding to LPCM. So there is no post processing other than what the Oppo can do. I sold my CBIII.
The CBIII + digi out it an alternative all digital approach, which is far more flexible (for starters you can switch multiple sources, and you have far superior bass management functionality). It uses a standard players' HDMI as source, decodes and sends to digi out card as LPCM. This has following drawbacks:
More expensive
Downsampling on sourcing above 48/24
Probably inferior sound quality, because the modded Oppo uses proprietary DSD-LPCM conversion and reclocking, and S/PDIF is inherently a better protocal to transmit high rez digital audio.
More expensive
You can configure the Trinnov to have multiple digital inputs, correct?
If so, then it seems that the ideal scenario would be to have both a Theta with digital out and a modded Oppo connected to the Trinnov MC. As you noted, the Theta would be for all the other sources (Kaleidescape, TV source, game consoles, etc.) and the Oppo would be for Blu-Ray above 48/24, 3D (since K* doesn't do 3D), SACD, and DVDA. That should cover just about everything and still be less than the ADA reference. Plus, this combination would also have DTS Neo X and the option for Dirac if you want it, two things the ADA reference doesn't have.
