AVS › AVS Forum › Audio › Speakers › Denon AVR 1312 with two Polk Tsi 200 Book shelve speakers advice needed
post #1 of 5
Dear Experts,
I have plan to improve my sound system , Presently I have been using SAMSUNG 40 LED TV with Videocon D2H HD.I have plan to by Denon AVR 1312 and two polk audio TSi 200 Book shelf speakers,Could I get descent audio with this configoration , now I have no plan to use surround speakers later I will upgrade with surround speakers. My use is 70 % Movies and 30 % Mussic , my room size is 13 ft x 11 ft.
Plaese advice with your recommendatios
Thanks in advance to all.
SAIFULLA
post #2 of 5
That sounds like a good way to go.
If it is within your budget, I would suggest that you also purchase a Polk PSW505 subwoofer, as you will probably want more low bass than the front speakers will have.
post #3 of 5
Originally Posted by saifucmp View Post
Dear Experts,
Depends on what your definition of decent is - and also your budget.
post #4 of 5
Are you getting the Tsi200s at a discount? If not the Monitor 40's are the same speaker for less.
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290202
If you wait for a sale, you could get the Monitor 60 towers for $120 each which is still probably less than the Tsi200s and a much better speakers.
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290206
They come on sale for $109-$119 ea quite often with free shipping.
post #5 of 5
fwiw, i would look into the denon avr1612 ( $199 at accessories4less) this step up will give you audyssey which will help you place your speakers in the best location and help configure the speakers for best sound .also some kind ofa budget would help
Edited by smasher50 - 8/28/12 at 1:32pm
  Back to Forum: Speakers
