AVS › AVS Forum › Gaming & Content Streaming › Networking, Media Servers & Content Streaming › Best way to wire TV USB to Server in basement?
post #1 of 2
I'm an amature compared to most. My LG LCD HDTV has a USB port to plug a hardrive in. I've used it often. My method to date is.. plug my 60 gig portable HD to my computer, transfer shows/movies onto it and then take it to the tv and viola.. can watch my shows.
How can I eliminate the back and forth? My iMac is in the basement.. about a 50' wire run from the TV. I thought about running a long USB.. but no such thing. I've seen USB-Ethernet converters? I've run all my own cable so no biggie?
Any other suggestions?
Thanks!!
post #2 of 2
Thanks!!
you can't because you can't have the USB HD plugged into your PC and TV at the sametime. Your stuck with sneaker net for the moment.
you could get a NAS that allows USB hosting like my old THECUS but I can't recommend anything THECUS makes. Their support and reliability is awful.
