AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › What's the DIfference: LG 60PV400 vs 60PA6500
post #1 of 5
A local store is carrying these 2 sets, with the A6500 being about $140 more. On paper, they look identical. I have searched the web, and while there is a ton of info on both these sets, still not seeing the difference. Is one last year's model (PV400), and one this year's (A6500). Or is one entry level and the other mid level, and if so, what makes it mid level.
Thanks for your time !!
Neil
post #2 of 5
I guess if none of you own the 60" versions, then let me ask this question another way. Does anyone know what the main differences are between the PV400 and A6500 series from LG? On paper they look identical.
Thanks for taking the time to respond !!
Neil
post #3 of 5
From pictures, it would seem that the PA6500 has thinner bezel and a different base.
post #4 of 5
Another difference is that the 6500 will play video via the usb port and the 400 only plays j pegs and mp3 files.
post #5 of 5
So basically a small visual difference around the bezel, and if one does not use the USB port, no biggy there. But from a performance and video spec point of view, is it safe to say that these 2 sets are identical??
