AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Best receiver for $100?
post #1 of 8
Best receiver for $100 that have a phono for vinyls and can power 2 bookshelf speakers and a sub.
post #2 of 8
For $100 with a phono input? Look for a good used receiver on Craigslist. I doubt there are any new receivers with phono inputs anywhere near $100.
post #3 of 8
And it won't power a sub. You'll have to provide your own powered sub. Nut yeah a used receiver off craiglsit is your best bet.
butter and jelly please.
post #4 of 8
Whatever receiver it is, it will have to be used. Nobody sells anything new like that.
post #5 of 8
post #6 of 8
Phono Pre-Amp.
But now you're into +$200.00 between the combined price of the AVR and Phono Pre-Amp which puts you back into used in order to get the price. I hate budgets.
post #7 of 8
Wolfetan44,
Now you can get a stereo receiver with a phono input for $100 but it doesn't have a line level sub output.
http://www.amazon.com/Sherwood-RX-4109-Stereo-Receiver-Black/dp/B000MBUSD6/ref=pd_sim_sbs_e_2
If your subwoofer has speaker level inputs you could connect the bookshelf speakers to Speaker A outputs and the sub to Speaker B.
If your subwoofer has speaker level inputs AND outputs you could wire the receiver to the sub with speaker A outputs and then the bookshelf speakers directly to the subwoofer. You would then use the subwoofer crossover dial to set your crossover point.
What subwoofer do you have?
post #8 of 8
used will be much better. Even go to goodwill and look at what they have.
