AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Best sub for $100?
Best sub for $100?
post #1 of 7
Best sub for $100 and in a 11x12 room.
post #2 of 7
post #3 of 7
The Monoprice 12"(the recommended $100 one) is discontinued.
post #4 of 7
Ok so I am getting the Dayton Audio Sub-1200.
post #5 of 7
post #6 of 7
save your money a bit longer
$100 subs aren't worth a purchase IMO.
post #7 of 7
you posted the same question twice, I'm deleting mine from the other thread.
Best sub for $100 is probably a used one that cost a lot more when new. check your local craigslist.
for new subs perhaps this parts express 10" sub
http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-628
and then take your pick after that....
Jamo sub 210 8"
http://www.vanns.com/shop/servlet/item/features/549114852/jamo-sub-210?s_c=site_search
Pioneer 8" sub
http://www.amazon.com/Pioneer-SW-8-Watt-Subwoofer-System/dp/B004MF2ZG6/ref=sr_1_20?ie=UTF8&qid=1346303561&sr=8-20&keywords=powered+subwoofer
same sub $79 after $80 discount at newegg.com
http://www.newegg.com/Product/Product.aspx?Item=N82E16882117402
Yamaha 8" sub
http://www.amazon.com/Yamaha-YSTSW012-Front-Firing-Active-Subwoofer/dp/B000TQ4D8K/ref=sr_1_3?ie=UTF8&qid=1346304035&sr=8-3&keywords=yamaha+subwoofer
Polk 10" sub (has low power)
http://www.amazon.com/Polk-Audio-10-Inch-Monitor-Subwoofer/dp/B0002KVQBA/ref=pd_cp_e_0
Afro GT
