AVS › AVS Forum › 3D Central › 3D Displays › Sony HMZ-T2 Personal 3D Viewer HMD Dedicated Thread
Sony HMZ-T2 Personal 3D Viewer HMD Dedicated Thread - Page 37
post #1081 of 1138
I owned the hmzt1 for six months and boy i hated it.
Can't get a good view blurry edges and the weight whas a big problem. So i sold it and heared about the t2. So take a change again and boy i whas glad that i did't. The weight is for me now acceptabel and in a half an hour a blurry free screen. For me the foreheadpad did't the trick. I put it a little to the front and that's it. Boy i'am glad that i bought this t2. Sorry for my bad english. I hope you understand.
post #1082 of 1138
Ok Kilrah on the laptop workaround. Comments on the fov are great and hopefully the resolution will improve with less stuff in the chain. I just got a sony 600 line HAD board camera from Security 2000 that has gotten a lot of good reviews to try. I also picked up a HDMI sender fron Ebay LINK to play with. Theres a Ebay fellow selling a 5 watt 5.8ghz amplifier brick that might make it useable. LINK
I'll let you know what I find when my H2 gets here..
Edited by tomzah - 8/13/13 at 10:44am
post #1083 of 1138
I'm afraid you wasted some money there...
That amplifier chip you bought is "just a bare chip", i.e. not useable without designing a whole circuit around it.
Those HDMI transmitters are known not to be useable. Fist thing is they use 4 independent transmitters in parallel, so you would need 4 amplifiers.
And even then, there is a return uplink from the "receiver" to the "transmitter" (a 5th radio), which if separated by too much distance will not answer in time anymore breaking the link, regarless of power.
post #1084 of 1138
Thanks Kilrah. I did not buy the amplifier brick yet. I know I need a power supply sequencer and some feedthroughs for it but it looked do-able. Do you do any RF work? Years ago I was active in Ham TV (*ATV) 0n 439 and 1200mhz. I built up several brick amps for both bands then.
I got the video sender in the mail today. The picture looks real good through it. I tried to search out info on the sender before buying via google but came up empty. Can you reference me a website or thread that discussed that sender. I would love to read about it still..
My T2 goggles never arrived. The seller claims she shipped it to the wrong address. I'm not sure if Im getting scammed but I know Ebay will take care of me.. It is causing a bit of a delay in aquiring the Sony T2..
BTW... Have you heard of any HD transmitters out there that might work??
thanks.again...
post #1085 of 1138
There have been quite a few discussions about using those WHDI transmitters for FPV a couple of years ago when they started appearing on the market. I tinkered with one myself but without going anywhere. A little search reveals things like this:
http://fpvlab.com/forums/showthread.php?6629-Low-latency-3D-HD-Wireless-Transmitter-for-FPV
which is a typical discussion on the matter.
HD for FPV is difficult. We've been hoping for a solution for several years now, with quite a few people who started working on promising things, but they all ended up giving up.
HD transmitters with suitable sizes and weights for FPV only started appearing in the broadcast industry about 2 years ago, but latency is still a bit too high for anything but "contemplative" flying (in the range of 100-200ms, I have the chance of having access to one through my job), and... for now a transmitter/receiver set costs approx. $25'000.
I'd expect we need another 2-4 years before it becomes possible and affordable.
post #1086 of 1138
Kilrah, I did get my H2 Display finally. Very happy with the pictures diplayed. And the Gefen Composite to hdmi converter works fine. The H2 accepts the video. Ran my Sony 600tvl through the Boscam 5.8 and everyting looks good. If only it was HD!
post #1087 of 1138
Cool, good news!
Not much new here, my BEC isn't there yet, the HDMI converter either (seems it's only shipped today from China frown.gif ), so I've only been using the T2 for some movie watching for now...
post #1088 of 1138
post #1089 of 1138
"These 2:
http://www.ebay.com/itm/Mini-Composite-RCA-CVBS-AV-to-HDMI-Converter-Adapter-Upscaler-For-VCR-DVD-720P-/350839941630?pt=US_Video_Cables_Adapters&hash=item51afb0a9fe
http://www.ebay.com/itm/AV-Audio-Video-Composite-Upscan-to-1080P-HD-HDMI-Converter-Adapter-PAL-NTSC-/251181574150?pt=US_Video_Cables_Adapters&hash=item3a7b96a806
(probably not the actual listings, but identical looking ones)
They are both switchable between 720p and 1080p, and with both the T1 does the same ("no signal" in one mode, " unsupported signal" in the other, no idea which leads to which though)"
hi...
im trying to convert a T1 to fpv goggles...
its good to hear that a simple bec can solve the power problems smile.gif what sorta running time can i get on a 2200mah?
Kilrah u mention the above to upscalers dont work on the T2.. do u guys know if they will work on the T1 ?
thanks!
post #1090 of 1138
I don't think they will work on either t1 or t2. Search for this item 161083890676 on Flea bay It works (I got one). Its a fair deal. I am using a 10 amp castle creation programmable bec set to 5.6vdc and it works very well. I added a spst switch to the back panel and I use it to switch from 110vac or 12vdc from a lipo. I left the original ac supply installed. The t1/t2 draws about 15 watts so a 2200 lipo should run it for 3+ hours (Ithink).
On another note... Since I wear prescription glasses I bought some fatshark corrective lens. Although a bit too small (1-2mm) they work well enough to use. They sure are more comfy than wearing my glasses inside the t1/t2..
post #1091 of 1138
post #1092 of 1138
So u can get hdmi to VGA adapters pretty cheap.. And a DIY VGA to RCA cable can be made.. Anyone try this yet?
post #1093 of 1138
No, as I wrote the converters were first tested on the T1 and weren't working. I was hoping they would work with the T2, but no.
Regarding your last post: the input of the T1/T2 is HDMI, so you need a "whatever you want TO HDMI" converter to use your stuff with the HMD.
We need to connect a composite source to an HDMI display. An HDMI to VGA converter is meant to connect an HDMI source to a VGA display.
Still no progress, not received neither the BEC nor the converter after 2 weeks. Hopefully they get there by the end of the week :\
post #1094 of 1138
My friend received his (2nd link). It does work with the T2, and gives pretty good image quality (better than the PC), albeit with probably a little more lag.
Unfortunately my friend got a dud, which apparently has a bad contact inside and tapping it a bit will make the picture switch to just some digital "broken picture" noise instead of the incoming picture.
So technically it works, but that particular unit is defective. Looking inside at least some pins of an LQFP chip seem to be badly soldered. I'm unfortuately not equipped to rework something this fine, so he'll probably try to moan and get it replaced.
Mine should be there tomorrow.
Edited by Kilrah - 8/29/13 at 2:23pm
post #1095 of 1138
We are all caught up on Comfort 3 cushion pads and orders. No waiting time now!
www.blazin3D.com
post #1096 of 1138
http://www.ebay.co.uk/itm/141045640777?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649
Selling my HMZ-T2's , Never used, boxed, with AC Adaptor for UK Power Outlet. £580.00 on EBay. A Huge Saving as I foolishly bought them from Bravo for over a grand.
Cheers,
Richard
post #1097 of 1138
wireless headset unit.... 3hdmi ... black colour still 720p
http://www.engadget.com/2013/09/03/sony-new-hmz-t3-head-mounted-display-wireless-hands-on/
Edited by vaktmestern - 9/3/13 at 6:44am
post #1098 of 1138
Hi,
"Bigger viewing sweet spot", what seems to be better padding + "semi-wireless" = I wana have! Also nice with the extra hdmi ports and battery. Any ideas how to convince the wife of the necessity of this unit if you already own a t2… Hm… Let’s see, I wonder if I could paint it white….?
post #1099 of 1138
I am very excited about this, comes out here in Japan this October and forsure we will sell them on our site and possibly make some pads if needed.
Once I get one I'll give a review about it for everyone also.
Something else interesting is Sony kinda announced a VR headset for the PS4 coming out later next year. It will be almost like the Rift.
post #1100 of 1138
Time to sell my HMZ-T2, lol.
post #1101 of 1138
Wireless haha a batterylife of 3 hours come on.
Bigger viewing spot the t2 is for me fine.
post #1102 of 1138
I stayed away from buying the T2 because it never made it to the US which, to me, only meant that Sony had something in the pipe they wanted to introduce with the PS4, which, btw, is NOT the T3.
http://www.techradar.com/us/news/portable-devices/ps4-oculus-rift-rival-in-the-works-as-sony-announces-head-mounted-display-1177670
As far as the T3, you might want to go to the T3 speculation thread and check the engadget link which has better pictures and reports an MSRP double that of the T2 just as the above link does.
There will also be a wired version available [hopefully much cheaper] and the rear top strap is now hinged so you can raise it as much as you want for better support and the nose gap seems to be bigger too.
Of course, if the selling price is double that of the T2, it might be better to just get a T2 when they become cheaper.
post #1103 of 1138
Originally Posted by Kilrah View Post
Cool, good news!
I finally got my FPV (first person view) airplane up using the T2 . The system works very good with no noticable lag. The silicon sun screens work well. I found RTV / silicone sealant glued the sun shades to the frame pretty good.
I have watched a bunch of HD movies in 3d and the resolution is outstanding. It really spoils you when then you have to view standard definition through them...
So far I am very happy with my T2 purchase. They work well for me.
post #1104 of 1138
The HMZ-T3 will be quite expensive, possibly over $2,000
post #1105 of 1138
If the HMZ-T3 is "possibly over $2,000" can you imagine what the comfort-friendly HMM-3000MT surgeons headset would set you back?eek.gif
Source
Edited by Paul H - 9/6/13 at 6:17pm
post #1106 of 1138
I hope there's no more "goggle halo" effect in the new T3.
post #1107 of 1138
how do they compare with fatshark predators -(if u have tried them)?
post #1108 of 1138
engadget claimed they would be $2,000 possibly. However, Japan price is only about $815
post #1109 of 1138
The unit is available for pre-order at sony.se for 11 499,00 SEK = 1 788 USD.
post #1110 of 1138
Unshure if i will jump in again .. curved 2D cinema mode is tempting
  Back to Forum: 3D Displays
