AVS › AVS Forum › 3D Central › 3D Displays › Sony HMZ-T2 Personal 3D Viewer HMD Dedicated Thread
Sony HMZ-T2 Personal 3D Viewer HMD Dedicated Thread - Page 20
post #571 of 1012
Yes I agree.
I have bought from you the pads for Sony HMZ Comfort 3 Cushion Pads LImited Edition. I am very satisfied and recommend it to anyone HMZ-T2 owners.
Already had the pads for the HMZ-T1, as well as the old pads have done a great service.
post #572 of 1012
Thanks guys, will be posting new items very soon.
post #573 of 1012
Tried a different head rest position last night, worked really well no sponge or pads.
I was so comfortable I fell asleep with it on xD.
post #574 of 1012
Head rest? You mean the back straps?
post #575 of 1012
The top pad, I used to have it all the way in, now I think I like it better out. More breathing room for my eyes I guess, lol. I got the picture sharp and thats all that matters.
post #576 of 1012
Some new products,
A carry protective bag for the HMZ-T1 and T2 versions. Made of a soft material and easily stores the HMZ inside with a snug fit. Even has a small pocket inside to hold the wire and inner headphones. Inside is made of an even softer fur like material to protect it.
And the new HMZ-T2 Pitch Black light blocker and forehead pad are out, the new pad straps on top of the original for extra comfort. The Sony pad is to hard and makes your forhead red, so with ours it reduces that and makes it much better to use.
post #577 of 1012
Bravia3D im sending you email in a min.
post #578 of 1012
Ok, sure.
post #579 of 1012
biggrin.gif hand up who gonna get them first \o/
post #580 of 1012
Will the new head pad slide or move all over the place?
post #581 of 1012
Nope, stays in place with the tight bands. Works pretty good too, really helps when I watch movies for long.
post #582 of 1012
Does your forehead still go numb tho? Mine falls asleep.
post #583 of 1012
Shouldn't, mine don't:cool:
post #584 of 1012
Hey AVS People!
Im trying to get my hmz-t2 to work but im a total newbie it seems because i cant get it to work anywhere not in my computer or xbox 360 or tv.
Glasses work fine i can change options but when i try to get a picture from tv or pc i get "no signal" and no picture. How do i use this thing and what am i doing wrong?
Thanks for the help!
post #585 of 1012
Originally Posted by deadman220 View Post
Hey AVS People!
sound like no signal going in your hmz-t2 box .
change your hdmi cable ( xbox or dvd player or blu-ray player or PC HDMI OUT into the hmz-t2 box HDMI IN) is the first thing to try and make sure to plug into hdmi in ( i attach image)
ps . make sure your setting on video on xbox as hdmi but it should detect automatically and on PC you need to go to controlpanel--->display to active it ( set hmz-t2 as 2nd screen or main screen, etc )
Edited by jommy999 - 12/7/12 at 11:41am
post #586 of 1012
Thanks for answering so soon! Am i supposed to put the hdmi cable to monitor or computer and where can i change the screen tried to find it but didnt
Thanks again for help :P
post #587 of 1012
basically your hmz-t2 is acting like 3DTV or 3DMonitor so you just have to set or do it as setting new TV or another monitor set so therefore you suppose to put hdmi cable from the back of your PC or laptop to HDMI out into HDMI IN in hmz-t2 box
For example : connect PS3 to Hmz-t2
HDMI OUT at the back of PS3 and Straight into at the back of Hmz-t2 HDMI IN
Edited by jommy999 - 12/7/12 at 1:08pm
post #588 of 1012
Hmm i dont see my hmz like in your picture my hdmi is connected to monitor should i connect it to my pc then?
post #589 of 1012
yes from your PC HDMI OUT, i connect my normal Acer monitor on DVI ,
if you think you do it right then you might have faulty hdmi cable. Do you have a spare different hdmi cable to try it ?
post #590 of 1012
Yes i have two hdmi cables and other one doesnt work either. Doesnt give picture and there is yellow triangle with "No Signal" in it.
post #591 of 1012
you shouldn't connect hdmi cable to your monitor at all , you only need to connect hdmi cable from hmz-t2 to the back of your PC
post #592 of 1012
i think try with your xbox first i think its easier ,
from the back of your xbox360 into Hmz-t2 and leave your normal TV alone
post #593 of 1012
I got it to work on xbox 360.
post #594 of 1012
yes ^_^ great to hear that .
now do the same with PC at the back of your PC case HDMI out stright into hmz-t2 and leave your monitor alone
post #595 of 1012
No luck with pc. How did you get it to work on pc?
post #596 of 1012
after connected to PC then you go to display setting at control panel and you have to active hmz-t2
( the name of SONY HMD should appear but then you tick on it and active it )
what graphic card you using ? if Nvidia then you go in to Nvidia control panel----> set up multiple display and active it ( see the box to tick SONY HMD in the picture )
Edited by jommy999 - 12/7/12 at 2:22pm
post #597 of 1012
i have nvidia options but i didnt see nothing there and nothing at display hmm
post #598 of 1012
i have nvidia geforce gtx 550 ti and i cant seem to change to hmz it doesnt even show
post #599 of 1012
maybe you need new driver , try to download and install see if it work
http://www.nvidia.com/Download/index.aspx?lang=en-us
post #600 of 1012
No luck. Still cant see hmz in display or get a picture
  Back to Forum: 3D Displays
