Depends on the projector and the technology used. I found it very apparent with the HMZ-T1. If you cannot see it, I would genuinely see about getting your vision checked.Quote:
That is John Carmack of id Software.Originally Posted by http://twitter.com/ID_AA_Carmack/status/193480540312190976
I finally actually measured the latency on the HMZ-T1. It is 50 msec worse than a Z800. 50! I am deeply appalled.
I doubt you would see a wireless unit any time soon. That would likely add considerable weight and substantiated or not, there would be concerns about sending wireless data to something strapped onto your head.1080p poses a problem for 3D—the current HDMI spec only supports 1080p24 and 720p60.
I bet it would be possible to send 1080p60 3D from a PC with one of those new 3GHz HDMI GPUs though.
Sony should done 2 things on the hmz-2 1080p and a wire less unit ...
and for a higher price
