The next generation of HDTVs is arriving, and it looks pretty incredible thus far:
Sony Electronics plans to launch an 84-inch 4K 3D TV at Sony Stores and select retail locations in North America later this year. Labeled as the XBR-84X900, this monster-sized HDTV will be equipped with a 4K (3840 x 2160) LCD panel packing Sony's 4K X-Reality PRO Picture Engine with up-scaling capability to 4K.
According to Sony, the 4K TV incorporates a 10 Unit Live speaker system which is optimized for the large-sized screen and envelops the viewer in virtual 5.1 surround sound. The side speakers are also detachable, allowing consumers to connect to an existing home theater system. The specs reveal that the 4K TV has a 50 watt total output, and a 10-unit speaker system including a subwoofer. Other audible features include a 10 degree inward facing array, and S-Force Surround 3D.
The spec list reports that the HDTV features a Dynamic Edge LED backlighting design, local dimming, full HD3D support, Motionflow XR 960 for a fluid framerate, and support for Wi-Fi Direct, DNLA and Skype. Users can also connect their PlayStation 3 and use the console's PlayMemories Studio to view, share and edit photos in 4K. PC and tablet content can even be streamed to the HDTV using Intelligent Connect.
I would imagine that most TV shows and movies wouldn't look that great on a 4K screen like this for a while, as the industry needs some time to catch up to this ridiculously high resolution.
How long do you think it will take for content to catch up to 4K?
http://www.tomshardware.com/news/XBR-84X900-4K-TV-3D-TV-Full-HD-PlayMemories,17262.html
