So I'm finally getting started on a project I've been looking forward to for a while, which is building some new mains for my home theater. I'm looking at building something in the vein of the Econowaves/4Pi/SEOS designs, and I thought I'd start a thread to post my progress and hopefully get some help from you guys that have done something like this before.
I know there are plenty of proven designs out there, but for this project I'd like to design the crossover myself as a learning experience (and this can actually count for course credit at my school, but it probably wouldn't be approved if I just worked off another design).
I've done a little research so far to try to narrow down the drivers and waveguide I'd like to use. I was originally going to do something more similar to the Econowaves, using the Dayton 12" and the QSC waveguide like in the Econowave Sr, but after reading through the SEOS thread, and looking at Java's great build. I'm getting really excited about the SEOS and the relatively inexpensive CD's on the diysoundgroup site.
Anyway, here's where I'm at with the drivers/waveguides:
Waveguides
QSC PL-000446GP Replacement Waveguide Horn for HPR152i ($35)
SEOS ($30) ( http://www.diysoundgroup.com/waveguides/seos/plastic-seos-matte.html )
Dayton H6512 ($7)
Compression Drivers
B&C DE250 ($130)
Denovo DNA 360 ($75) ( http://www.diysoundgroup.com/drivers/tweeters/dna-360.html )
Denovo DNA 350 ($57) ( http://www.diysoundgroup.com/drivers/tweeters/dna-350.html )
Selenium D220Ti ($50)
Woofer
Eminence Deltalite-II 2512 ($150)
Eminence Delta Pro 12A ($135)
Eminence Delta 12LFA ($100)
Dayton Audio PA310-8 ($65)
I'm leaning heavily toward the SEOS + DNA360 + 2512 combo, but if anyone else could weigh in (especially with the woofers) it would be helpful. Like how much would I sacrifice going to the 12A? And why haven't I really seen any mention of the 12LFA?
Budget-wise I can make the SEOS + DNA360 + 2512 work, but spending less is always good, so I guess the main question is if I would notice a large difference of quality saving a few bucks on drivers.
Edited by Scott C. - 9/4/12 at 4:00pm
Waveguides
Dayton H6512 ($7)
Compression Drivers
B&C DE250 ($130)
Woofer
, but I used the 2512 in my SEOS build and am extremely happy with them.
